need help with a B18b block
Old Nov 10, 2005 | 11:10 AM
callinthe187's Avatar
Default need help with a B18b block
one of the holes that the bracket goes into the block for the mounts is broke...the left top one is it fixable.....
Old Nov 10, 2005 | 12:09 PM
corradoproblem's Avatar
Default Re: need help with a B18b block (callinthe187)
how is it broken? is it stripped out or is it really broken off if its stripped you can tap it and fix it, if its broken (cracked) id say that block is pretty much ruined unless you know somebody who knows how to repair aluminum
Old Nov 10, 2005 | 06:16 PM
Default Re: need help with a B18b block (corradoproblem)
its cracked off like i had the piece in my hand.....but im sayin though is it fixable
Old Nov 10, 2005 | 06:42 PM
skecthy. you would need someone to weld some aluminum on there(maybe the peice) and then drill and tap the hole, if you can get that done it might be ok
Old Nov 11, 2005 | 07:36 AM
ud think itll be safer if i just get another block
Civic89stdB16
Sep 19, 2009 09:30 PM
Phatch99
Oct 26, 2005 09:22 AM
boosted3g
Jul 31, 2002 12:55 PM
