Thermostat problems?
Old Nov 15, 2005 | 03:16 PM
Shizznaz's Avatar
Default Thermostat problems?
I was just sitting the the parking lot at school and I noticed that my engine sounded slightly different. I checked the temp gauge and it was just fine. But when I turned the engine off and got out of the car, I heard the sound of water sizzling. I popped the hood and saw nothing. Got down on the ground and I saw a TON of water on the ground and it was dripping from the cat. I didnt know at the time what the problem could be but my buddy told me its my thermostat.
About 6 or 7 months ago I had to replace the thermostat because it went bad. Now, I have to change it again. That doesnt sound right to me so does anyone know why my thermostat is going bad so fast? and also, from what I described above, does it sound like its the thermostat even? That'd be good to know for sure.
Old Nov 15, 2005 | 08:04 PM
Shizznaz's Avatar
Default Re: Thermostat problems? (Shizznaz)
Anyone?
I put about a liter and a half into the radiator and drove it about 20 mins and when I got back home, I let the engine sit with a fan on it till it was cool and when I checked it, the radiator was still full ... Why did it leak so suddenly and then stop leaking?
Old Nov 15, 2005 | 11:20 PM
BaNAnABoAt689's Avatar
B A N N E D
From: los angeles, Eagle Rock, CA, united states of america
doesn't make sense, is your car overheating?.. but the radiator still full.... is there bubbles??
i personaly thing someone was trying to f* with your ride and put water in the exhast..
Old Nov 16, 2005 | 02:31 AM
rainforest's Avatar
Default Re: Thermostat problems? (BaNAnABoAt689)
are you sre it wasent the evap drain tube you are leaking coolent the car will overheat eventually. also chech that one of you heater core hoses dident bust.
Old Nov 16, 2005 | 07:15 AM
Shizznaz's Avatar
Default Re: Thermostat problems? (rainforest)
well no one could have been Fing with me because I was in the car the whole time and the sizzling wasnt coming from the muffler. It was coming from where my exhaust goes from 2 pipes to 1. Because I have a DC sports 4-2-1 header. So where the 2 meets the 1, its dripping there and sizzling so technically, if the intake manifold was off, you could see it by just looking down on the engine. Thats where its coming from.
And when I checked the radiator after I noticed the sizzling, it took 1 and a half liters of water so it was LOW. And luckily, it didnt overheat. And Like I said, after I filled up the radiator I drove it about 20 mins and it didnt overheat and after I let the engine cool, there was no radiator fluid missing. So it seemed to be fine. I drove it to work this morning and theres no signs of dripping. =/
Old Nov 16, 2005 | 07:56 AM
JimBlake's Avatar
When my GSR waterpump began leaking, it would occasionally burp out a nice puddle. Maybe 3 or 4 ounces, usually during cooldown after turning off the engine. Strange thing, it didn't leak when running, I never could understand why. After putting the new pump in, I looked carefully at the old one, it looked perfect.
Also, it leaks down the outside of the timing cover, to the oil pan gasket. Maybe yours is flowing around the lip of the oil pan & dripping down onto the exhaust?
Old Nov 16, 2005 | 09:18 AM
Shizznaz's Avatar
Default Re: Thermostat problems? (JimBlake)
nope. I have a brand new water pump on the engine. not even a month old I dont think. And when it was dripping before I replaced the water pump, it was dripping from a different area. I can tell for sure.
AcuraFanatasism
Sep 20, 2009 02:55 PM
DaveSi677
Jul 5, 2006 10:35 AM
twenty
Jul 21, 2005 04:32 PM
LoooseGSR
Jul 15, 2003 10:49 PM
