Reuse headbolts?
Old Nov 7, 2005 | 08:25 PM
djtony5's Avatar
Default Reuse headbolts?
I'm really short in money right now and was wondering if I could maybe re-use my headbolts just once? It look like it in good condition.
Old Nov 7, 2005 | 08:31 PM
mmuller's Avatar
Mad Scientist
Default Re: Reuse headbolts? (djtony5)
yeah
Old Nov 7, 2005 | 09:31 PM
sporkcrx's Avatar
Default Re: Reuse headbolts? (mmuller)
I did, then a couple months later the headgasket started leaking. So I had to tear it all apart again, put in a new head gasket, and threw in some arp head studs. I'm never making that mistake again
Old Nov 7, 2005 | 09:34 PM
mmuller's Avatar
Mad Scientist
Default Re: Reuse headbolts? (sporkcrx)
yep, thats the other side of the coin;
your always taking a chance with headbolts
Old Nov 11, 2005 | 04:29 PM
boost'd_crx's Avatar
i wouldnt recommend reusing stock ones.
Old Nov 11, 2005 | 04:58 PM
Astig's Avatar
Default Re: Reuse headbolts? (boost'd_crx)
$80 bucks now, or 2-3x that soon!
Just buy new headbolts, or wait til you have the money!
Old Nov 11, 2005 | 08:07 PM
TSM's Avatar
TSM
I wouldent do iy
Old Nov 11, 2005 | 08:19 PM
djtony5's Avatar
I really want to order some new arp headbolt, but i'm really short in money! On the helm manual, they did not states anything about reusing headbolt or not. What are the chances of leaking? Is it pretty minimal?
Old Nov 11, 2005 | 09:00 PM
MustangPunk302's Avatar
Default Re: (djtony5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtony5 &raquo;</TD></TR><TR><TD CLASS="quote">I really want to order some new arp headbolt, but i'm really short in money! On the helm manual, they did not states anything about reusing headbolt or not. What are the chances of leaking? Is it pretty minimal?</TD></TR></TABLE>
You never know man, it's not writen in stone. If you do though, dip them in straight 30 weight oil/or anti-seize.. I've reused stock head bolts many times, though on iron head/blocks, could diffenlently be worse on your all aluminium motor...
Old Nov 12, 2005 | 02:02 AM
Astig's Avatar
Default Re: (MustangPunk302)
Honda head bolts are considered "Torque N Toss" , but its your motor!
Old Nov 12, 2005 | 07:48 AM
djtony5's Avatar
aaaaa screw it I'm going with arp head bolts..time for more downtime.
Old Nov 12, 2005 | 11:44 AM
Astig's Avatar
Good choice. Do it right the first time.
Old Nov 12, 2005 | 04:07 PM
gsrious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtony5 &raquo;</TD></TR><TR><TD CLASS="quote">aaaaa screw it I'm going with arp head bolts..time for more downtime.</TD></TR></TABLE>right one brother... the downtime right now will pay off though. think of it as just a tad more downtime now or a whole bunch later.
**anyhow, good choice.
Old Nov 12, 2005 | 07:10 PM
projectTeG's Avatar
ive reused mine 2 times...the previous owner had work done and i dont know if they replaced the bolts or not.
1. previous owner did head work( which was done wrong)..not sure if bolts were replaced.
2. i took head off to inspect the problem and replaced headgasket
3. replaced valve seals and re-used head gasket because it was 3 weeks old.
i have had no problems whats so ever...no coolant loss, no abnormal oil loss, no coolant/oil mixture, and the work was done almost 2 years ago and had numerous races/redlines on it.
i was told you can reuses them a few time but dont over do it, this go around with my bottom end rebuild im opting for arp headstuds
beatontheeznutz
Apr 11, 2012 03:52 AM
92eg6lsvtec
13
Jul 7, 2005 10:01 AM
s2kkk
May 15, 2005 03:22 PM
Weapon_R
Dec 13, 2004 04:06 PM
93LSivic
Sep 3, 2003 11:43 AM
