Timming belt help!!!.. asap
Old Nov 10, 2005 | 07:29 PM
Tony_EM1's Avatar
Default Timming belt help!!!.. asap
so im building a lsvtec for my em1 and im finally done... just need to put the timming belt and drop it in... ive been tryin to put the timming belt on now for like about 1 hour with the motor out.... im just about to rip my hair out... ne suggestion... thx in advance...
Old Nov 10, 2005 | 08:04 PM
trucdoken's Avatar
i had the same problem. so i used the bosch vtec water the pump. the gear is a little smaller so makes it easier to slip on the tbelt.
Old Nov 10, 2005 | 08:17 PM
zman's Avatar
Default Re: (trucdoken)
which water pump you are using determines which timing belt you should use.
If you are using a vtec water pump 22 teeth you need a gsr/itr timing belt, but if you are using a ls water pump 19 teeth you need the ls timing belt.
Timing belts can just be a PITA sometimes, if you ask me.
rick_rabies
Apr 1, 2009 12:59 PM
a1320honda
Aug 5, 2007 07:33 AM
EFOSV
Jun 16, 2004 07:22 PM
dElSleepiE
Jun 1, 2003 08:56 PM
Boost2NA
Oct 31, 2002 03:36 PM
