rev limiter/speed cut
Old Nov 13, 2005 | 02:29 PM
dragaholic's Avatar
Default rev limiter/speed cut
HI guys,
Is it possible to have both speed cut and rev limiter removed from an ecu without it being chipped?
Old Nov 13, 2005 | 03:45 PM
Blaze45's Avatar
Brrraaaap!
Default Re: rev limiter/speed cut (dragaholic)
Why would you want to remove the rev limter? No, to answer your question BTW.
Blaze
Old Nov 13, 2005 | 04:52 PM
SVOboy's Avatar
Yep, gotta chip it, ain't that expensive anyway.
Old Nov 13, 2005 | 08:19 PM
dragaholic's Avatar
not that I want to do it, it was done to when I bought the car.
So since it is chipped what a good program for a b16a3 with bolt ons.
Old Nov 14, 2005 | 04:05 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (dragaholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragaholic &raquo;</TD></TR><TR><TD CLASS="quote">not that I want to do it, it was done to when I bought the car.
So since it is chipped what a good program for a b16a3 with bolt ons.</TD></TR></TABLE>
Stock.
There is no such thing as "a good program". Every engine is different and should be tuned specifically for your motor.
Old Nov 14, 2005 | 04:25 AM
TurboCoop's Avatar
Default Re: (JDM_Ej)
You could get a rev/speed meter and remove your speed/rev limiters. But Im sure you can find a cheaper way to blow up your motor... rev limiters are a good thing
Old Nov 14, 2005 | 06:00 AM
drdisco69's Avatar
Default Re: (TurboCoop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop &raquo;</TD></TR><TR><TD CLASS="quote">But Im sure you can find a cheaper way to blow up your motor... rev limiters are a good thing</TD></TR></TABLE>
lol, well put.
Old Nov 14, 2005 | 02:16 PM
dragaholic's Avatar
thanks guys.
Is the stock limiter at 8k? Is it safe to rev to 8500?
Old Nov 14, 2005 | 03:37 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragaholic &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys.
Is the stock limiter at 8k? Is it safe to rev to 8500?</TD></TR></TABLE>
NO!
theres no point on stock valvetrain/cams.
you'll just drop a valve.
Old Nov 14, 2005 | 04:58 PM
dragaholic's Avatar
thank you
Old Nov 16, 2005 | 04:30 AM
TurboCoop's Avatar
dont lie, youre going to try to do it anyway arent you? My friend with a stock GSR powered EG raised his to 9K and dropped a few valves within a week, plus its not making any more power up there so dont do it, or another engine will be killed.
fahad.999
Honda Civic (2001 - 2005)
Aug 21, 2011 07:35 AM
Singlecam4dr
Jan 27, 2007 11:50 AM
bruce-si
Jan 21, 2006 09:31 PM
projectxthelimit
Oct 12, 2005 06:52 PM
