what would u recommend for an old engine?
Old Nov 15, 2005 | 09:41 AM
dropped like its hot's Avatar
Default what would u recommend for an old engine?
Im planning on picking up this engine but it has nearly 200k on it. What would u guys recommend to do to take care of a motor this old, it does burn some oil, so would rings, pistons etc. be a wise idea?
Old Nov 15, 2005 | 10:06 AM
zman's Avatar
Default Re: what would u recommend for an old engine? (dropped like its hot)
new bearings and thrust washers, fresh hone is a definate with new rings, if you are going to buy new pistons buy over sized ones and bore it a little for a fresh start, thorough cleaning, balance the rotating assembly if your picky, new oil and water pump, gasket set, valve seals if you wanna touch the head.
Old Nov 17, 2005 | 05:16 PM
eastbay92cx's Avatar
Default Re: what would u recommend for an old engine? (zman)
I would have to recommend some boost to freshen up it's day.
Old Nov 17, 2005 | 05:33 PM
trrbl1bmx's Avatar
due to past experience, oil doesnt just burn from the pistons. check valve guides, valves, and seals.
nearbeer2001
Apr 11, 2017 10:24 PM
Mishako129
Feb 6, 2014 06:55 PM
acura_b18c1
Apr 18, 2011 01:42 PM
quik1
May 17, 2004 07:15 PM
