JDM headlights ?
Old Nov 12, 2005 | 10:30 AM
redEH2's Avatar
Default JDM headlights ?
does any one know how to wire up 92-95 jdm eg headlights on to a usdm car ? i need to know how to wire the daylights aswell . Any help appreciated . Thanks
Old Nov 12, 2005 | 11:29 AM
ladysman's Avatar
Default Re: JDM headlights ? (purpleEJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purpleEJ6 &raquo;</TD></TR><TR><TD CLASS="quote">does any one know how to wire up 92-95 jdm eg headlights on to a usdm car ? i need to know how to wire the daylights aswell . Any help appreciated . Thanks</TD></TR></TABLE>
Splice the daylight wires into the corner lights. That is what I did. Works fine.
Old Nov 12, 2005 | 08:16 PM
redEH2's Avatar
Default Re: JDM headlights ? (ladysman)
cool thanks man . i knew a guy that had a set but the corners would not turn on unless you got the turn signal on .
Old Nov 13, 2005 | 10:41 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purpleEJ6 &raquo;</TD></TR><TR><TD CLASS="quote">cool thanks man . i knew a guy that had a set but the corners would not turn on unless you got the turn signal on . </TD></TR></TABLE>
THis is an incorrect wiring job.
Old Nov 13, 2005 | 11:09 AM
Keith Pierson's bitch's Avatar
you can wire them to a switch if you want... in case you dont always them on
Old Nov 13, 2005 | 07:22 PM
redEH2's Avatar
Default Re: JDM headlights ? (xxturbodreamsxx)
can you use the same light bulbs as usdm headlights ?
Old Nov 14, 2005 | 08:26 AM
yea, all the bulds should be same, as long as they fit in the hole you should be good
5G_Vtec
Mar 14, 2007 07:40 AM
spintboy
Jan 26, 2007 06:14 PM
mikelax125
Honda Civic (2001 - 2005)
14
Oct 10, 2006 06:04 AM
USDM Tsuchiya
Feb 2, 2004 04:19 PM
