D16 Question
Old Nov 7, 2005 | 08:57 PM
lowridincivic92's Avatar
Default D16 Question
I have done some research and couldnt answer the question, which is can a D16z6 head fit on a d15z1 block and if so where can i find these heads because no local places have any. Also i would like to know what heads will fit this block and what year and make are they from. Also what all would be needed to make this swap possible and what kind of power gains could i expect to see?
Modified by lowridincivic92 at 3:07 AM 11/8/2005
Old Nov 8, 2005 | 12:30 PM
bump for help
Old Nov 8, 2005 | 06:24 PM
Old Nov 9, 2005 | 05:46 PM
help please
Old Nov 9, 2005 | 07:18 PM
builthatch's Avatar
MiG-21 superfan
Default Re: (lowridincivic92)
http://www.d-series.org
Old Nov 11, 2005 | 11:50 AM
still looking for info.
Old Nov 13, 2005 | 08:33 PM
Old Nov 14, 2005 | 07:09 PM
sanimalp's Avatar
$cat /dev/urandom
a z6 head is out of Civic EX/Si /Del Sol Si 1992-1995. i havent done the swap personnaly but i believe it falls under the mini-me swap category.. and youll go from about 92 hp to about 130ish because of upped compression and vtec. search for mini-me and youll get the answers you need. most all 88 and up d series heads are compatible with d series blocks.
Old Nov 14, 2005 | 07:41 PM
EnzoSpeed's Avatar
Default Re: D16 Question (lowridincivic92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowridincivic92 &raquo;</TD></TR><TR><TD CLASS="quote">can a D16z6 head fit on a d15z1 block</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> where can i find these heads because no local places have any.</TD></TR></TABLE>
They sell daily on ebay for about $75.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> Also i would like to know what heads will fit this block and what year and make are they from. </TD></TR></TABLE>
It doesn't matter - the z6 head you are asking about is already the best possible option.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Also what all would be needed to make this swap possible </TD></TR></TABLE>
-New set of head bolts
-New head gasket
-P28 ECU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and what kind of power gains could i expect to see? </TD></TR></TABLE>
That depends. Your vtec-e motor not only has a crappy head, it also has a crappy intake and exhaust components. Once you swap to a vtec head, you'll also want to open the intake up. If you can't afford headers and a cat-back, then at least upgrade to a z6 exhaust manifold (about $60 on ebay).
If you do the head swap, get an AEM intake, and at least get the z6 exhaust manifold, then you should easily see 130hp.
Old Nov 16, 2005 | 08:20 PM
ok well i have a full exhaust headers back and an intake. plus the head will be P&P. but will the headers i have now fit because they are expensive headers but the intake is ebay quality. and i was think about goin with a y8 IM for a bigger airflow. Any opinons?
Old Nov 17, 2005 | 09:41 AM
gameboi's Avatar
i hear they say that this set can take b16's...is it true...
Old Nov 17, 2005 | 10:31 AM
builthatch's Avatar
MiG-21 superfan
did you check out http://www.d-series.org? search around on there and you will find more d-info than you need
Old Nov 17, 2005 | 03:25 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowridincivic92 &raquo;</TD></TR><TR><TD CLASS="quote">ok well i have a full exhaust headers back and an intake. plus the head will be P&P. </TD></TR></TABLE>
Sounds good. HP is a hard estimate with so many new variables, but you could easily be at 150+ hp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">but will the headers i have now fit</TD></TR></TABLE>
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> a y8 IM for a bigger airflow. Any opinons?</TD></TR></TABLE>
Sounds like a great choice.
vtechappy
Jun 13, 2010 06:02 PM
DJYoshaBYD
Dec 9, 2009 06:28 PM
turbovybez
Dec 7, 2006 08:32 AM
coreypoppej6
Jun 26, 2005 09:32 AM
Nine
16
Apr 23, 2003 12:08 PM
