Will a obx lsd fit a cable transmission without modification
Old Nov 13, 2005 | 12:49 PM
crxvtecturbo's Avatar
* B A N N E D *
Default Will a obx lsd fit a cable transmission without modification
i just bought a obx lsd i know all the bad things about it allready but does this lsd fit without modification or what needs to be done to make this work in a cable transmission
Old Nov 13, 2005 | 03:06 PM
* B A N N E D *
Default Re: Will a obx lsd fit a cable transmission without modification (crxvtecturbo)
Old Nov 14, 2005 | 04:39 PM
HondaCivicSiR1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxvtecturbo &raquo;</TD></TR><TR><TD CLASS="quote">^^^^^^^^</TD></TR></TABLE>bump because i would like to know if it will fit a s1 also
Old Nov 14, 2005 | 06:11 PM
* B A N N E D *
Default Re: Will a obx lsd fit a cable transmission without modification (HondaCivicSiR1)
bump
Old Nov 15, 2005 | 06:35 PM
94ludeh22's Avatar
I just put one in my H23 transmission. It fit perfect with no modification. You just add your stock gear around it. Also, you will have to order new bearings for it. At a honda dealership, mine cost me about $120. Remember, when removing the factory gear around you factor differencial, that the bolts in it are reverse threaded. In other words to take them off, put your wrech on tighten.... atleast most honda trannys are like that.
And on the "bad things" about OBX's LSD. I wouldnt worry about it unless your going to go over 350 HP. I know ppl running it right now who have had it for a couple years with NO problems. They are both running around 325 WHP. Let me know if you have anymore questions.
civic2slo
Mar 9, 2009 07:48 AM
baulum
Jul 22, 2008 03:12 AM
spooolin
Jun 16, 2006 10:04 AM
jDMJeRk
Dec 23, 2003 07:31 PM
7rrivera7
Feb 21, 2003 03:22 PM
