ported ls head vs vtec head
Old Nov 12, 2005 | 04:16 PM
89a6T's Avatar
Default ported ls head vs vtec head
car(ls) is going on boost but i want to know which is better for the money. spend $4-500 to have the ls head ported or spend 5-600 for vtec head swap.
Old Nov 13, 2005 | 10:13 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: ported ls head vs vtec head (89a6T)
i had the same problem i have a ls head that was going to be p&p for a ls-t set-up that i was set on doing but i came across a good deal on a gsr head($300 with arp head studs) figured if you have the money for the vtec head get it..later p&p it. you will be one step ahead meaning you have that more of a foundation.
Old Nov 13, 2005 | 10:35 AM
onepoint6i's Avatar
Default Re: ported ls head vs vtec head (DBL)
In my opinion i would stick with LS head and use that money to tune the turbo perfectly.. With the right setup and engine managment...Youll see enough gains with the Ls head/turbo setup.....
Forced induction loves any head design, up the boost and it'll make power regardless...
I wouldnt even port the Ls head..Ive seen sevaral single cams, Ls's make alot of power with stock port, im talking 250-450 Hp...
head porting for turbo is not critical like for AllMotor power...
Old Nov 13, 2005 | 11:14 AM
TunerElite's Avatar
Stock, i think the vtec heads flow a little bit better, but a p&p ls head would do just nicely for a turbo setup
Old Nov 13, 2005 | 12:02 PM
Fkned's Avatar
I personally would get a vtec head rather then port an ls head.it may cost more if you need to get cams,int-exh manifolds,etc also,but you'll be better off in the long run imo.
Old Dec 1, 2005 | 07:18 PM
all go teg's Avatar
Default Re: ported ls head vs vtec head (Ed's Racing Heads)
bump, i also am looking at the two options, can anyone else give some information on the subject?
Old Dec 1, 2005 | 08:52 PM
airshifter's Avatar
vtec
bradysyde
Mar 20, 2013 07:04 PM
RudeLude83
May 20, 2007 03:50 PM
skn181
May 13, 2007 10:49 PM
Cyphear
May 3, 2007 09:35 PM
b20turboic
Nov 20, 2005 07:59 AM
