Heavy Fluid
Old Nov 10, 2005 | 12:45 AM
Mavrick's Avatar
Default Heavy Fluid
What is the heaviest type of tranny fluid you can safely put in a manual honda transmission? Ive got bunged seals, I need heavy stuff but how heavy?
Old Nov 10, 2005 | 12:53 AM
Cuda70's Avatar
Default Re: Heavy Fluid (Mavrick)
You got the tranny out, correct?
The seals are pretty cheap and very easy to install... why not go that route?
Old Nov 10, 2005 | 12:39 PM
Mavrick's Avatar
Default Re: Heavy Fluid (Cuda70)
input shaft seal
Old Nov 10, 2005 | 12:52 PM
corradoproblem's Avatar
id fix the leak instead of going with a heavier tranny fluid. Too thick and the car will be hard to shift and can lead to damage. fix the input seal and run the specified fluid
97CWITR
Jul 18, 2011 08:05 AM
Sean DM
Honda Civic (2001 - 2005)
Sep 25, 2006 02:28 PM
Elwuudz
Jan 15, 2006 07:54 PM
Lo-Buck EF
Apr 16, 2002 10:12 PM
