reading a compression test
Old Nov 14, 2005 | 02:37 PM
teefunk01's Avatar
Default reading a compression test
my compression test reads 160-160-160-0
this is a bone stock gsr motor...also makes a ticking noise soungs like a valve definitely not loud enough to be a rod.
If it is a valve it should be in that 1st cylinder that reads 0 but can anyone explain why the compression is so low in the other 3 cylinders?
Old Nov 14, 2005 | 03:30 PM
onepoint6i's Avatar
Default Re: reading a compression test (tphan4)
i wouldnt be worring about the 160 part, worry about the 0 part
you ate a valve more than likely....
Old Nov 14, 2005 | 06:01 PM
teefunk01's Avatar
Default Re: reading a compression test (onepoint6i)
so you think if i replaced the valve....the rest of the cylinders would bump back up?
Old Nov 14, 2005 | 06:15 PM
rainforest's Avatar
no they wouldent. each sylinder is independant to the next. the only time that the other cylinder would be effected on a compression test would be if there was a crack in the cylinder, cylinder head, or a blown headgasket. check your readings again. 0 is a very unlikly number. sounds more the the gauge is defective. unless there isint a piston in that cylinder.
Old Nov 14, 2005 | 06:32 PM
teefunk01's Avatar
Default Re: reading a compression test (rainforest)
O my bad....I did blow the headgasket...i forgot to add that part
Old Nov 14, 2005 | 06:33 PM
teefunk01's Avatar
im just trying to make sure that when I replace the head with a spare head im using, that the valve would be the only problem. Im just worried that maybe the other low compression readings would come back to haunt me. Like after putting it all together and then facing something else going bad. thanks for the inputs
Old Nov 14, 2005 | 07:20 PM
onepoint6i's Avatar
when you pull the head, inspect the cylinder walls really good, more than likely your comression was 160 because of the blown gasket...make sure you pay the machine shop to inspect the head before they resurface it...lets us know the outcome
Old Nov 14, 2005 | 07:57 PM
teefunk01's Avatar
btw the cylinder that reads 0......when I was taking out the sparkplugs...it was covered in oil and alot of oil in there
Brandon Peters
Oct 18, 2015 05:40 PM
Team_Coast978
Engine Management and Tuning
Jun 10, 2013 10:58 AM
91EF919
18
Aug 4, 2009 12:50 PM
Da1spaz247
Nov 4, 2005 07:57 PM
street dreams
Nov 21, 2004 04:48 PM
