o2 sensor
Old Nov 15, 2005 | 12:59 PM
ozir's Avatar
Default o2 sensor
Im thinking of buying a set of airmass headers from a friend.They're of a 98 civic ex and I have a 98 civic lx.On the headers there is an o2 esensor hole at the bottom.On my stock manifold its up at the top and one below the cat.Will these fit my civic and is there a wy to relocate the sensor?TIA for the help
Old Nov 15, 2005 | 01:01 PM
Kendall's Avatar
If you cut the loom off of the wiring harness, you should be able to pull the O2 sensor wires to the proper location. Then reloom the harness.
Old Nov 15, 2005 | 02:47 PM
Slow ass EF's Avatar
Default Re: (Kendall)
he has 2 o2 sensors. read before you post it sounds like it will not work unless you modify the harness and make it read only one of the sensors
Old Nov 19, 2005 | 05:11 PM
ozir's Avatar
is there a way to do that and make it work?the one sensor and two harness setup.
zerodohc
Jan 10, 2013 12:41 PM
InTheZoneAC
12
May 25, 2011 07:08 PM
sol_1
May 21, 2009 12:34 PM
team 15
12
Mar 29, 2007 06:03 PM
SiFactor
Feb 27, 2006 05:57 AM
