Transmission Seal
Old Nov 9, 2005 | 07:31 PM
Mavrick's Avatar
Default Transmission Seal
is the main transmission seal seated just around where the input shaft comes from the back of the tranny to the front? The reason I ask is because my clutch was slipping badly, so I take her all apart to find out that the clutch meat looks just as big as my new replacement, but I seem to have oil on the transmission end of the flywheel but not the rear end indicating theres not a problem with my engine seal. Am I correct?
Old Nov 9, 2005 | 07:48 PM
Jim Truett's Avatar
Default Re: Transmission Seal (Mavrick)
Sounds like a leaky input shaft seal. You will need to disassemble the tranny to replace it. It is directly behind the ISB.
Old Nov 9, 2005 | 08:12 PM
Mavrick's Avatar
Default Re: Transmission Seal (Jim Truett)
could i just use a heavier gear fluid instead of 10w-30 like gear oil or 10w40 or even straight 40 to stop the leak
djnikko
Honda Motorcycles
Jan 13, 2012 05:24 AM
tvtecEG9
Jul 19, 2011 07:43 AM
Integra4lyfe069
Aug 7, 2009 08:16 AM
Mavrick
Nov 9, 2005 10:45 PM
blackfrohatch
Jan 3, 2003 08:02 AM
