need help with problem
Old Nov 10, 2005 | 10:23 PM
Bartman201's Avatar
Default need help with problem
ok so i have a b18b, i just turbo charged the car. everything was fine till today. there is no pressure on the top radiator hose. car is idleling funny. what can it be?
Old Nov 10, 2005 | 10:37 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: need help with problem (Bartman201)
could be the waterpump... that would cause a funny idle if it has seized if it were the headgasket i think the upper hose would be rock solid. do a compression test and see what happens. does it overeat at all?
Old Nov 10, 2005 | 10:41 PM
Bartman201's Avatar
Default Re: need help with problem (wantboost)
no the temp is fine. no overheating just funny idle it moves up and down from like 1000 to 7000.
Old Nov 10, 2005 | 10:45 PM
wantboost's Avatar
Who is Mr Robot?
thats a pretty big jump... i doubt a headgasket or waterpump would cause that...that sounds electrical
Old Nov 10, 2005 | 10:47 PM
Bartman201's Avatar
electrical like what?
how about no pressure on the radiator hose?
Old Nov 10, 2005 | 10:52 PM
wantboost's Avatar
Who is Mr Robot?
thats not electrical... over time hoses get old and get soft.. that could be what it is... it could be a headgasket, water pump, thermostat.. but none of those would cause the idle fluctuations
Old Nov 10, 2005 | 10:57 PM
Bartman201's Avatar
i took my car once to this guy and he squesed the hose and i think he said the headgasket was bad not sure thats why i asked. well if i do replaced it wich one will be good for turbo. i have low comp pistons 9:1 and a blockgard. im boosting 9psi.
Old Nov 10, 2005 | 10:58 PM
wantboost's Avatar
Who is Mr Robot?
squeezing a rad. hose is no way to tell if a hg is good or not... just get an oem gasket.. best you can buy.
Old Nov 10, 2005 | 11:03 PM
Bartman201's Avatar
ok, in the morning ill do a comp test. ill change the water pump, thermoS, headgasket. just in case. last time i changed them was 3 years ago.
thanks wantboost
Old Nov 10, 2005 | 11:04 PM
wantboost's Avatar
Who is Mr Robot?
no problem... post back if nothing changes
Old Nov 10, 2005 | 11:05 PM
Bartman201's Avatar
cool i will.
90dacarlton
Dec 16, 2012 05:59 PM
defnu
Jun 18, 2009 05:59 AM
949
33
Jul 9, 2008 07:12 AM
superturboprelude
Apr 30, 2006 03:36 PM
hollaback6
Jun 3, 2003 10:04 AM
