Electrical Issues
Old Nov 13, 2005 | 05:42 AM
ShrimpPoppa's Avatar
Default Electrical Issues
Recently I noticed that my turn signals weren't working on my 90 Civic HB. The culprit was a blown fuse, so it was an easy fix. After replacing the fuse, I drove for about 10 minutes when I noticed a burning smell. Somehow, the fuse melted versus blowing. When this happended it blew the STOP/HAZARD fuse in the engine compartment fuse box. The problem is that now when I attempt to replace the STOP/HAZARD my starter kicks on. I was thinking that maybe when the TURN SIGNAL fuse melted that it messed up the MAIN RELAY. Any help on this would be appreciated.
Old Nov 13, 2005 | 10:40 AM
onepoint6i's Avatar
Default Re: Electrical Issues (ShrimpPoppa)
did you install a bigger fuse than rec'd?
the main relay does not give power to your starter..
Old Nov 13, 2005 | 11:17 AM
Default Re: Electrical Issues (onepoint6i)
I replaced the blown fuse with the same 10A that I had taken out of there. I just can't figure out why the starter would go when I replace the STOP/HAZARD fuse.
Mishima
Jun 30, 2009 09:08 PM
tuan...
Aug 7, 2004 05:47 AM
ModlesSI
Feb 22, 2003 03:16 PM
AdamITR
Sep 14, 2001 08:25 AM
