Weird Cold Starting Problem
Old Nov 16, 2005 | 11:39 AM
jdmkrazie's Avatar
Default Weird Cold Starting Problem
My car seems to have problems starting every now and then. I turn the key and all i hear is a click. I know it isn't the battery or alternator. So the only thing could be starter. Although, after i compression start it and drive it to where ever i'm going.. I can shut it off and start it right back up. Anyone have a clue why this is? Battery doesn't like the cold? Starter is having problems in the cold?
Getting tired of pushing my car, and starting it like it's a cool race car.
Old Nov 16, 2005 | 12:01 PM
jdmcars.com's Avatar
Default Re: Weird Cold Starting Problem (jdmkrazie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkrazie &raquo;</TD></TR><TR><TD CLASS="quote"> I know it isn't the battery or alternator.
Are you sure. The problem seems more like the battery. The cold weather can effect a battery. If you were having troubles with the starter, I would lean more into saying it would be all the time, not just when it is cold.
Old Nov 16, 2005 | 02:43 PM
-ILLICIT-'s Avatar
cold start injector(is it injected lol- multi pint or single???) check resistance and put AN LED test light across the plug to check it, cannot stress how important it is to use an led test light and not a tungsten(t draws too much current, also on/off is to slow for injectors)
Old Nov 16, 2005 | 08:12 PM
jdmkrazie's Avatar
Default Re: Weird Cold Starting Problem (illicit_)
[/QUOTE]Are you sure. The problem seems more like the battery. The cold weather can effect a battery. If you were having troubles with the starter, I would lean more into saying it would be all the time, not just when it is cold.[/QUOTE]
Yeah, that's what i'm thinking too. We'll see in a second when i try to start it for work. I mean if I can compression start it.. that doesn't mean that the battery is good right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illicit_ &raquo;</TD></TR><TR><TD CLASS="quote">cold start injector(is it injected lol- multi pint or single???) check resistance and put AN LED test light across the plug to check it, cannot stress how important it is to use an led test light and not a tungsten(t draws too much current, also on/off is to slow for injectors)</TD></TR></TABLE>
no it's not an injector problem
Old Nov 17, 2005 | 10:31 AM
unsungsohc's Avatar
check all your grounds and the signal wire going to the starter itself. if any of these are lose or bad it could cause miscellaneous starting problems.
Old Nov 17, 2005 | 11:36 AM
jdmkrazie's Avatar
Default Re: Weird Cold Starting Problem (unsungsohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unsungsohc &raquo;</TD></TR><TR><TD CLASS="quote">check all your grounds and the signal wire going to the starter itself. if any of these are lose or bad it could cause miscellaneous starting problems.</TD></TR></TABLE>
i doubt thats the problem. reason for that is because if i can compression start it. then it isn't a ground. i'm thinking it's the battery because sometimes when i just hold the key there it'll eventually turn over. any other ideas?
Old Nov 17, 2005 | 12:16 PM
doublejz's Avatar
maybe your main relay takin a **** on ya
Old Nov 17, 2005 | 02:15 PM
jdmkrazie's Avatar
Default Re: Weird Cold Starting Problem (doublejz)
nope not that either =] i've already had that problem and fixed it. that was when i first got the car.
Old Nov 22, 2005 | 07:15 PM
jdmkrazie's Avatar
update: the car still starts... and haven't really had any delay. it also hasn't been as cold i think. so i'm thinking it could just possibly be the battery or something retarded. cuz every now and then i'd have to hold the key there a little longer than usual before it even cranks over.
for example.. turn key.. click.. hold it there... 1 sec.. 2 sec.. 3 sec.. cranks over and starts.
love_my_ekcoupe
Jan 26, 2010 08:20 PM
dvlsfan30
Oct 21, 2008 05:09 AM
dohc_profile
Oct 12, 2007 11:32 PM
Sticky Tires
Feb 12, 2003 01:18 AM
integranator
Jan 12, 2003 10:52 AM
