Car bogs when vtec engages
Old Nov 10, 2005 | 08:30 PM
civicstar's Avatar
Default Car bogs when vtec engages
The car was running perfectly fine before i had to drop the tranny to change the clutch and oil. After a few days, it started bogging out when vtec engaged. I tried different P28s and different chips in each one. Some with the jun chip, then spoon chip then skunk2 chip. i tried everything from vtec at 5000 to 5900. i checked the fuel pressure at set it at 45. the motor is LS VTEC with GSR head. It has CTR pistons but the head is stock with stock cam gears and cams. It has a skunk2 I/M. The injectors are 310ccs. Everything was running perfectly fine until after the oil change. i checked the o2 sensors and everything but there are no CEL. i tried a different Vtec Solinoid and even cleaned out the one i had fully but it still bogs out.
Old Nov 10, 2005 | 11:34 PM
92bubblesi's Avatar
Default Re: Car bogs when vtec engages (civicstar)
Opps. didn't see the Skunk2 IM
>> Are your secondaries opening?
Old Nov 11, 2005 | 05:05 AM
Hulkdon1's Avatar
Since you took down the tranny, I would look at the grounding wire on top of the tyranny to see if the contact is good. Make sure the area around the ground wire is clean.
chad174
11
Mar 23, 2013 10:19 PM
DougGsrHatch
11
Feb 25, 2008 10:50 AM
lsvteccivic
Oct 18, 2006 04:17 PM
ensracer
20
Jun 21, 2005 03:42 PM
that_guy
Oct 3, 2003 01:30 AM
