Help on wiring up a fan toggle switch?
Old Nov 15, 2005 | 09:37 AM
WS6Dreams's Avatar
Default Help on wiring up a fan toggle switch?
I have a 91 Accord and the fans only turn on when I shut the car off. I replaced the fan module and same thing happens. So I know the fans work, theres just probably a short somewhere, so I want to just wire a toggle switch straight to the fans to turn them on/off when I want. I am horrible with wiring so any help would be appreacited. First off I dont know what wires to go to or how to get into any of this. Please help. Thanks in advance.
-Blake
Old Nov 15, 2005 | 12:36 PM
JimBlake's Avatar
Default Re: Help on wiring up a fan toggle switch? (WS6Dreams)
The fan switch in your thermostat housing should be responsible for turning on the fan when the engine's running. With the key on, unplug that & jumper the plug with a paperclip or something. That should make the fans run.
If that doesn't work, you've got a wiring problem to fix, before your toggle switch is gonna work.
If it works, then get a simple switch, run a pair of wires out to the engine. Connect one wire to each of the wires on that same plug. Leave them also connected to the original fan switch, for the times when you don't remember to use your new switch...
Old Nov 16, 2005 | 11:59 AM
WS6Dreams's Avatar
Default Re: Help on wiring up a fan toggle switch? (JimBlake)
You mean on the coolant temp. sensor? Just jumper that clip?
Old Nov 16, 2005 | 01:11 PM
JimBlake's Avatar
Well, I don't have a '91 so maybe I'm confused. I hope someone with a '91 chimes in here.
I looked on hondaautomotoveparts.com but didn't really find what I'm looking for. I expected to see 2 sensors in the thermostat housing, one for the ECU & the other is a fan switch. Maybe they did something different that year?
What I said to do is for the fan switch. Once we actually find where it's located...
Old Nov 17, 2005 | 07:00 PM
WS6Dreams's Avatar
Man I REALLY appreaciate all your help. Where do you think I could start to look? Also where are you from in Ohio?
Old Nov 21, 2005 | 04:58 AM
JimBlake's Avatar
I sorta remember someone saying the fan switch was on the back of the block for some years? Maybe on the back of the head? But it's probably not real swift to randomly unplug stuff & jumper the wires together...
It's pretty certain that the on on the UPPER radiator hose nozzle is a fan switch. If you unplug that & jumper the wires, does the fan run (with the key on)? If so, you can use that one for your switch. Otherwise, you'll have to find a wiring drawing for your year or get a repair manual.
I'm not too far away from Akron...
Old Nov 21, 2005 | 06:42 AM
WS6Dreams's Avatar
I figured it out. Thanks Jim!
trrbl1bmx
16
Aug 2, 2006 11:51 AM
HxCforever
Mar 10, 2006 05:52 PM
Sick79
Jan 18, 2005 09:02 AM
Ausmith
Aug 10, 2003 12:24 AM
therealciviczc
Jun 7, 2002 01:18 PM
