Apexi Vafc2 install help
Old Nov 13, 2005 | 05:13 PM
m1jdmcb7's Avatar
Default Apexi Vafc2 install help
I have a 93 accord ex with a 95 h22 motor swap and was looking into installing a vtec controller myself.. I have seen it installed before at my last job and I have worked with wiring before but with a 240..
I would like to know which ecu I am running.. There isn't anything on the ecu itself that says which one it is. In the Apexi wiring diagram booklet there isn't a drawing that looks like mine, the closest to it I found on: http://www.apexi-usa.com/pdfInstallation/24.pdf and its the top left WH-1.
Besides that I just would like to know if anyone here has installed one on their cb7 hybrid.. and if anyone can help or would know of a DIY I can go by..
Any help would be much appreciated.. I can send pictures if anyone feels it would help.. Thanks a lot, Ryan AIM: spidersk8
Old Nov 13, 2005 | 05:36 PM
bigwhitebucket's Avatar
Default Re: Apexi Vafc2 install help (m1jdmcb7)
http://www.hondata.com/techecuid.html
That should help you find out which ecu your running.
As far as install, that pdf file is what you need. If you aren't that confident then find someone to install it for you. If you've graduated from velcro to strings you should be fine
Old Nov 13, 2005 | 06:32 PM
m1jdmcb7's Avatar
Default Re: Apexi Vafc2 install help (bigwhitebucket)
K Thanks with that I was able to find out which ecu I am running.. OBD1 p72..
nicolaselias
Dec 10, 2010 08:53 PM
Tink2150
Oct 5, 2005 06:46 PM
ringgold
Jul 31, 2004 07:18 PM
bulori
Nov 11, 2002 10:42 AM
