Need help in choosing correct rod bearing.
Old Nov 8, 2005 | 02:02 PM
djtony5's Avatar
Default Need help in choosing correct rod bearing.
Both of the rod has the number 3 stamped on it. And on the crank, both of them use the letter C. And that match up with C-3-brown. So this would be the correct part number for it correct? 13213-P72-003 BROWN.
1998 gsr btw..
Old Nov 9, 2005 | 08:15 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Need help in choosing correct rod bearing. (djtony5)
Give it a shot.. don't forget to plastigage it.
Old Nov 9, 2005 | 09:20 PM
djtony5's Avatar
Plastigage the new bearing to check if it match standard specs?
Old Nov 10, 2005 | 12:13 AM
-ILLICIT-'s Avatar
Default Re: (djtony5)
yep, just chuck a bit about as wide as the bearing surface on the crank surface and tighten up to specs WITH a TORQUE wrench, ive seen guys take guesses and seize a motor, then remove and check gap, if all good the just re-do bolts up to specs again and away you go
95hondasedan
Nov 17, 2014 07:45 AM
TravisCadello
Mar 13, 2009 04:35 PM
gus straussen
Apr 9, 2008 11:38 PM
bluedlude
39
Jan 27, 2008 12:42 PM
Wicked Sol
Jun 15, 2002 09:23 AM
