How do I correct my air/fuel mixture??
Old Sep 20, 2002 | 08:11 PM
fowler!'s Avatar
Default How do I correct my air/fuel mixture??
I installed a skunk2 manifold a while back on my gsr motor. Ever since my idle has sucked ***. I've adjusted the air fuel mixture screw thing but it's not really helping.
All I want is a consistant 750-800 rpm at idle.
I've heard that you disconnect the ecu/battery then unplug the IACV and all should be golden.
I did that and nothing...
So...there has to be something that I'm not doing. Any clue?
tia
Old Sep 20, 2002 | 11:53 PM
sa21199's Avatar
Default Re: How do I correct my air/fuel mixture?? (fowler)
does the idle jump up and down or is it just really low? If its jumping up and down you have a vacum leak...check all the lines to make sure everything is tight.
Old Sep 21, 2002 | 06:40 AM
fowler!'s Avatar
Default Re: How do I correct my air/fuel mixture?? (sa21199)
The RPMs pretty much stay at like 1100...sometimes they'll jump between 1000-1500, but that's not that often..
Old Sep 21, 2002 | 10:45 AM
erniecars's Avatar
that sounds like it could be a vacuum leak. what ecu are you using? Have you set the idle with a digital tac?
Old Sep 21, 2002 | 01:32 PM
fowler!'s Avatar
Default Re: How do I correct my air/fuel mixture?? (erniecars)
a repogrammed P28...it's starting to surge again..so, I'm thinking it could be a vaccum leak..
Old Sep 21, 2002 | 01:50 PM
brainwo's Avatar
New User
I would say.. check TPS.. or the throttle cable..
20vt_gtx
14
Dec 27, 2019 04:50 AM
afnan
Apr 30, 2014 09:48 AM
downshift3r
Sep 30, 2013 06:34 AM
jdm.ejone
Jun 15, 2008 04:50 PM
EJ8chu
Engine Management and Tuning
32
Jun 1, 2008 10:19 AM
