skunk2 chip
Old Sep 21, 2002 | 08:17 AM
arjusmc's Avatar
Default skunk2 chip
i was wondering what it takes to install a chip. i have 95 integra ls and a skunk2 chip i picked up for cheap. do you just snap it in on the ecu some where or am i going to have to send it away to get it done?
Old Sep 21, 2002 | 08:28 AM
-Whitey-'s Avatar
Default Re: skunk2 chip (arjusmc)
you tape it to the hood and it has a lil magnet in it that reaches the motor then tells it to be faster
Old Sep 21, 2002 | 10:33 AM
arjusmc's Avatar
Default Re: skunk2 chip (one_honda)
thanks for the reply. i think if i had no life i would leave sarcastic replys on honda tech forums too. moron
[Modified by arjusmc, 7:33 PM 9/21/2002]
Old Sep 21, 2002 | 12:04 PM
piatl7il77's Avatar
you have to know how to solder and remove the solder. if you dont then you should take it to a shop they usually know how to install them. but if you do it yourself then there is a little spot on the ecu that the chip goes in it has a white boarderline around it. that is were the chip goes it is like in one of the corners.
Old Sep 21, 2002 | 12:55 PM
kenji's Avatar
25 Year Member
Default Re: skunk2 chip (speed23lan)
I am in the Tampa Bay area. I can install your chip.
Email me if you are interested. Thanks.
-kenji
Old Sep 21, 2002 | 05:15 PM
B18C-EJ1
Guest
Posts: n/a
Um, as far as I know, Skunk2 doesn't make a chip for the non-VTEC.
And there's more to installing that chip than just soldering it in.
Since Kenji is in your area, have him do it.
Old Sep 21, 2002 | 08:44 PM
blundar's Avatar
Default Re: skunk2 chip (B18C-EJ1)
pgmfi.crx-forum.org
if ya wanna do it yourself...
SKUNK2 = JUNK2 chipwise
Old Sep 21, 2002 | 11:46 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: skunk2 chip (blundar)
humor is good medicine. obviously you must be sick.
codine
Engine Management and Tuning
May 3, 2010 01:53 PM
em1pusha99
Apr 14, 2010 05:15 PM
revlimitcrx
Apr 13, 2006 02:17 PM
jonathan13
Aug 1, 2005 03:31 PM
Sp33dStarVirus
May 29, 2003 06:06 PM
