How to duplicate vss signal? Which Guage Cluster?
Old Sep 17, 2002 | 09:58 AM
LS-Rt's Avatar
Default How to duplicate vss signal? Which Guage Cluster?
My P61('93 GSR) ECU is not getting a vss signal. I have tried everything and can't get it to work. My car has been converted from ODB0 to ODB1 and it's almost impossible to find a '92-'93 GSR guage cluster. Do you guys know if any other clusters would be compatible?
I am now at the point where I am looking to trick the ecu with a square wave signal generator http://www.gibsonteched.com/CK030.html
Do you guys think this will work?
Old Sep 17, 2002 | 10:21 AM
CHEETAH's Avatar
Default Re: How to duplicate vss signal? Which Guage Cluster? (LS-Rt)
not clear, your 92/93 gsr was an obd1 setup fromt he factory, what do you mean you converted from obd0 to obd1 ? are you looking for a 92-93 gsr cluster or are you looking for a VSS to run with the P61 ecu ? or both ?
greg
Old Sep 17, 2002 | 10:31 AM
LS-Rt's Avatar
Default Re: How to duplicate vss signal? Which Guage Cluster? (CHEETAH)
Alright, I have a 1990 ls that has been completely converted from ODB1 to ODB2 and received a '93 b17 swap. All is good except for the guage cluster and the little harness that goes from cluster to main car wiring harness. Throwing code 17(vss).
Can't find a GSR cluster (Very Rare).
That's my situation.
Options:
1)Find used cluster (doubt I can find one)
2)Trick ecu with square wave generator (ghetto)
3)??? any other ideas?
Old Sep 17, 2002 | 11:41 AM
CHEETAH's Avatar
Options:
ok this ismuch better ... LOL
for now get an electronic VSS to fix the ecu, B10 on ecu will go to pickup on VSS, if oyu have an obd1 harness it should plug right in. This will be quick fix for ecu, and you'll have vtec now, you wont have a speedo reading at your cluster. I may have an electronic cluster at hoime in pieces if I find it maybe you can salvage parts from it ... otherwise if you wanna buy a Type R cluster, I have one for sale, jsut need to fit it in there ... I have bezel too.
if you dont have an electronic VSS lemme know I also have abotu 20 of them.
Greg
Old Sep 17, 2002 | 12:16 PM
LS-Rt's Avatar
You've got IM Greg
Electric vss was the first thing I was going to do but my redline starts at 6500 on this cluster so I wanted a cluster with a higher redline.
But you have reminded me of this option and it's probably the best thing at this point. I guess I'll just have to invest in a mechanics manual to do the wiring back to speedo.
The G2 ODB1 tegras don't have connectors in the harness for electircal vss, that's '94+ only but it's no big deal. I believe the wires are power, ground and signal right?
Thanks
Tom
chad
Apr 7, 2009 03:04 PM
Turbo Dan
May 11, 2008 02:26 PM
420aNT
16
Mar 21, 2005 12:20 PM
n1neb4ll
Jan 25, 2004 01:05 PM
