Removing the Water Pipe on the back of the block?
Old Sep 19, 2002 | 11:45 AM
Ri5e's Avatar
Default Removing the Water Pipe on the back of the block?
How do you remove that Water pipe on the back of the block that connects to the Water Pump? It is 1 1/2 Inch in Diameter. I removed the two 10 mm sized bolts. Then tried yanking it, its loose but it won't come out.
Old Sep 19, 2002 | 02:04 PM
Chiovnidca's Avatar
Default Re: Removing the Water Pipe on the back of the block? (4 Stroke)
Wiggle and pull. Don't forget to remove the hoses.
Old Sep 19, 2002 | 02:06 PM
GruvyTune's Avatar
New User
Default Re: Removing the Water Pipe on the back of the block? (Chiovnidca)
agreed, pain in the *** but will come out with wiggle and pull method. cut my fingers doing mine.
Old Sep 20, 2002 | 08:31 PM
3rdGteg's Avatar
Default Re: Removing the Water Pipe on the back of the block? (GruvyTune)
I wiggled and pull and pried mine out w/ a flathead. It's the rubber seal thats being a bich.
Old Sep 21, 2002 | 02:38 AM
Westrock2000's Avatar
Default Re: Removing the Water Pipe on the back of the block? (3rdGteg)
speaking of which how do you remove the thermostat, do I have to do something with little plug on the outer area?
NZstan
Apr 16, 2010 09:15 PM
Mikes1098
Apr 20, 2009 05:35 PM
shilly
Oct 7, 2008 02:42 PM
GalDemSuga
Jan 15, 2007 05:54 AM
