What size injectors, 270cc or 310cc
Old Sep 17, 2002 | 11:14 AM
bikeboy80's Avatar
Default What size injectors, 270cc or 310cc
Im trying to figure out what size would be best for my motor:
B18b, 11.3:1 CR, Crower 403 cams, Jdm header and 2.5 inch exhaust, ported and polished, balenced, fpr, safc (hondata down the road or something) blah blah blah
that is for right now, in the near future i will be adding: intake manifold, 64mm tb
i'm probally looking at being around 200whp, so what should i be looking for, 270 or 310? also should i get saturated or peak?
sorry if i sound a little vague, injectors are probally one of the only things im unsure about, thanks
Old Sep 17, 2002 | 11:23 AM
sgT's Avatar
sgT
Default Re: What size injectors, 270cc or 310cc (bikeboy80)
310cc saturated should be good for your app
Old Sep 17, 2002 | 11:38 AM
bikeboy80's Avatar
Default Re: What size injectors, 270cc or 310cc (sgT)
thanks
Old Sep 17, 2002 | 03:14 PM
Austin's Avatar
Agreed
Old Sep 17, 2002 | 04:29 PM
non-VTEC's Avatar
not to be an *** but with that setup your not going to see 200whp.........so the stock injectors should be just fine.........
if you can find a set of 97+ prelude VTEC injectors (280-290cc) then just go for those. but even then you will probably not need them.
good luck
Old Sep 17, 2002 | 07:04 PM
bikeboy80's Avatar
Default Re: What size injectors, 270cc or 310cc (non-VTEC)
may i ask how you know this? do you have personal experience?
Old Sep 17, 2002 | 07:09 PM
non-VTEC's Avatar
i happen to know someone with a B18B with 12.5:1 endyn pistons. race ported head and crower 404's, skunk2 manifold, bored T/B plus all the other bolt on goodies and he's making about 180-185whp tuned with a wideband o2 sensor......
403's are pretty mild.......i have the 403's and i like them but 200whp N/A with the 403's is very un-realistic.....
[Modified by non-VTEC, 11:10 PM 9/17/2002]
Old Sep 17, 2002 | 07:50 PM
ExospeedAMcrx's Avatar
the 310's might be overdoing it.
your motor would survive with just under 300's, sumthing like a 270 is good enough for now.
Old Sep 18, 2002 | 04:27 AM
bikeboy80's Avatar
do you know what size injectors he is running?
i will probally just stay stock for now utill I can get some dyno tuning done and she what the motor is doing, but I guess it would be good to go for the 270s for nothing else than to keep the fuel pressure a little lower, right? or would this still be over kill?
Old Sep 18, 2002 | 08:43 AM
Austin's Avatar
good luck
Sir...I must correct you, on my Type-R with a Mugen head gasket, HyTech header and exhaust, an intake, and cam gears...I also have Hondata, while tuning we datalogged some of the information and found out that the injectors were at 100% duty cycle, and I was only at ~180 whp before the final tuning. Stock injectors are not adequate for an modified vehicle...I'm in the process of switching out to some '97+ Prelude injectors which are 290cc/min as opposed to the stock injectors which are rated at 240cc/min.
Also when I had Toda B cams I maxed out the 310cc/min injectors...had them logged at 98% duty cycle, switched out to 440cc/min injectors and they were at a comfortable ~70% duty cycle.
Some applications and vehicles require more fuel than others...my current setup is producing more power than my old Toda setup and requires smaller injectors, there are many variables playing parts in your cylinder efficiency.
Austin
Old Sep 18, 2002 | 09:42 AM
skunked's Avatar
Default Re: What size injectors, 270cc or 310cc (Austin)
I think a set of 310's would be nice but not completely necessary. I have 198hp/140tq on stock 94GSR injectors. I know I can probley get a little more with some 270 or 290 prelude injectors. That would be ideal.
Old Sep 18, 2002 | 02:24 PM
non-VTEC's Avatar
depends what your long term goals are...........310's would be good if you have a S-AFC and FPR to de-tune them in the lower RPM so you wont run overly rich. and later on if you plan upgrade to something bigger/better you have the fuel capacity for it.....it's your choice.............
my freind is running stock injectors. and he had a custom ECU dyno tuned with a wideband o2 sensor. it was tuned by a well known tuner.......probably one of the best so i would assume that the stock injectors did just fine for his setup......
if you can find a set of prelude VTEC 290cc injectors then go for those...........there probabaly the most cost effective........
good luck
H-EK22
Feb 22, 2008 11:42 AM
92 white eg
May 16, 2007 09:54 AM
DC4_MADMAN
Oct 21, 2006 08:00 PM
See Are X
Dec 14, 2005 07:29 AM
