HELP! My pulley fell off!
Old Sep 19, 2002 | 04:07 AM
David G's Avatar
Default HELP! My pulley fell off!
as the title says the pulley that runs my ac and power steering fell off while i was driving. so how the hell do i put it back on. these are the parts i picked up from the road, am i missing something?
[Modified by H2OCivic95, 3:19 PM 9/20/2002]
Old Sep 20, 2002 | 06:19 AM
David G's Avatar
Default Re: HELP! My pulley fell off! (H2OCivic95)
ttt
Old Sep 20, 2002 | 07:11 AM
Mikey's Avatar
your crank pulley fell off! holy crap.
it looks like you've got the pulley, bolt, and two of the three belts
AC, PS, Alternator
I dont know the torque spec of the crank pulley bolt, so I guess I'm not that much of a help
Old Sep 20, 2002 | 07:12 AM
racerxadam's Avatar
is that the crank pulley? you will probably need to get a new key. it goes in a little groove on the crank and lines up with a little groove on the inside of the pulley. it makes sure that the pulley is put on in the correct position relative to the crank.
Old Sep 20, 2002 | 07:44 AM
94CivicSi's Avatar
Default Re: HELP! My pulley fell off! (racerxadam)
yes, get a new woodruff key. When the key is in, you can't put the pulley on wrong. Be sure that bolt is torqued to about 125-130lb/ft. Replace all those belts while you're in there too.
Old Sep 20, 2002 | 01:35 PM
Chiovnidca's Avatar
Who left the bolt loose? How long have you been driving it like that? I hope it didn't tear up the end of the crank too bad.
Old Sep 20, 2002 | 01:41 PM
Nameless RB26's Avatar
Default Re: HELP! My pulley fell off! (Chiovnidca)
whoa
Old Sep 28, 2002 | 12:25 PM
David G's Avatar
Default Re: HELP! My pulley fell off! (C5_ALLMOTOR)
got it fixed, a buddy of mine that works at acura helped me out. He told me that there was a recall on this, so for any of you with 95's should check in on it just in case.
acmoc
11
Apr 29, 2009 11:59 AM
tag0617
Apr 12, 2009 06:13 PM
white_panther
Dec 8, 2006 04:47 PM
david90
Aug 15, 2003 01:15 PM
littledan
Aug 12, 2003 08:57 AM
