blown GSR block still good???
Old Sep 19, 2002 | 04:51 PM
See Are X's Avatar
Default blown GSR block still good???
I found a GSR bottom end that sucked up water and blew the motor. I think it was just the first cylinder thats messed up, theres a big whole on the side of it. Right now its sitting outside and has been rained on and everything. I was just wondering if there was anything I can recover from this block??
Old Sep 19, 2002 | 07:28 PM
MaRkO's Avatar
Default Re: blown GSR block still good??? (See Are X)
I guess if it's still in a good condition.
If it's that bad then i would consider you hot tank it then bore and resleeve it!!
Hey can't let a GSR block go to waste...
[Modified by MaRkO, 6:28 PM 9/19/2002]
Old Sep 19, 2002 | 08:31 PM
Ri5e's Avatar
hm...hole. Dont think its good if there is a hole in the block.
Old Sep 20, 2002 | 05:21 AM
See Are X's Avatar
Default Re: blown GSR block still good??? (4 Stroke)
would the oil squirters be any good???
Old Sep 20, 2002 | 05:27 AM
miller's Avatar
where is the whole? is it like a small whole in the sleeve or is it like through the outside of the block?
Miller
Old Sep 20, 2002 | 08:46 AM
ill phil's Avatar
Default Re: blown GSR block still good??? (vtecdoc)
My guess- hydrolock, bent rod and piston went through sleeve. Verdict: take the block to a machine shop, get it checked out and see if its salvageable (crank, resleeving, etc.) still good, send it out to Golden Eagle and get it redone (that will cost some $).
I mean- verdict: Block is crap, sell it to me for cheap And if you don't feel like dealing with all that to get it fixed PM me I might be interested.
[Modified by ill phil, 5:48 PM 9/20/2002]
Old Sep 20, 2002 | 10:07 AM
Farnsrocket's Avatar
Default Re: blown GSR block still good??? (ill phil)
Yeah, where is the hole, in the sleeve or the block?
Old Sep 20, 2002 | 10:59 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: blown GSR block still good??? (MaRkO)
get it resleeved and bored again and you're set
01DC4
Oct 17, 2011 08:44 PM
dam_teg
Sep 25, 2009 12:37 PM
b18-crx
Aug 3, 2009 01:37 PM
mehrshadvr4
May 11, 2009 01:07 PM
