lube for engine rebuild?
Old Sep 21, 2002 | 11:17 AM
integRated109's Avatar
Default lube for engine rebuild?
block is back from the machine shop and im about to start re-assembly. just wondering what kind of lubricant you use, if any, on the internal pieces. thanks.
Old Sep 21, 2002 | 12:44 PM
Default Re: lube for engine rebuild? (integRated109)
top???
Old Sep 21, 2002 | 12:48 PM
tk's Avatar
tk
You can use 20w50 on the rings and assebly lube for the bearings , cam and rockers.
Royal Purple and Clevite make real good ones
Old Sep 21, 2002 | 01:14 PM
Default Re: lube for engine rebuild? (tk)
thanks tk
Old Sep 21, 2002 | 02:59 PM
Mr. Choi's Avatar
New User
um, you should be using an engine assemble lube. ususlly a moly based lube or something. the lube is more of a grease than oil so it will stay where you up them. dont use engine oil cause they will jus run out and you'll have a dry engine. go buy some engine assembley lube.
for tk
[Modified by Chois i-VTEC, 4:00 PM 9/21/2002]
Old Sep 21, 2002 | 04:12 PM
Michael Delaney's Avatar
Default Re: lube for engine rebuild? (Chois i-VTEC)
http://www.redlineoil.com/redlineoil/asslbeti.htm
http://www.torcoracingoils.com/products/index.htm
we use either Torco MPZ engine and cam assembly lube or Redline assembly lube.
Old Sep 21, 2002 | 05:17 PM
Default Re: lube for engine rebuild? (Michael Delaney)
thanks guys. im sick of being carless, thats why im doing the assembly myself.
devin0606
Mar 21, 2017 12:45 PM
steveo135
May 8, 2008 04:44 AM
DeDonDeRosa
Apr 11, 2003 10:48 PM
GettaluvR
Jun 27, 2002 11:14 AM
