need some advice with motor building...
ok im finally starting on my motor work....
(after all this time) well, as of right now i have a B16 in my hatch & i have a complete GSR block ready to get built. im looking to build a serious n/a strip/street motor and this is what i have divised so far for the block...check it out and give me your opinions an thoughts and if so help me critique my ideas. thanks.
B18C1 block
resleeved 85mm bore
LS crank ( 89mm stroke opposed to 87.2mm )
Eagle Rods
Forged pistons (dont know what brand yet)
new bearings, vtec oil/water pumps
(after all this time) well, as of right now i have a B16 in my hatch & i have a complete GSR block ready to get built. im looking to build a serious n/a strip/street motor and this is what i have divised so far for the block...check it out and give me your opinions an thoughts and if so help me critique my ideas. thanks.B18C1 block
resleeved 85mm bore
Eagle Rods
Get everything balanced and inquire about chamfering the oil holes on the crank.
What piston r u gonna use (CR) ? That's a good starting point w/ the GSR block/LS crank.
X2
My suggestions would be:
Keep the GSR crank
Go with Endyn RollerWave pistons (he has that compression you want in 85mm)
Eagle rods
I just built a B20/VTEC, so I'm pretty familar with all this good stuff.
Keep the GSR crank
Eagle rods
Keep the GSR crank
Eagle rods
Keep the GSR crank
Eagle rods
Another reason to keep the GSR crank is the rod/stroke ratio. The better R/S ratio of the GSR takes more kindly to high rpm's, important when building an N/A motor.
I agree, keep the GSR crank. You'll be much happier with the revs (not to mention life) that the shorter stroke will give you. This is why I'm building my new LS with a B16 crank and rods. The last race engine didnt like holding together at 9900 consistantly.
Well first, send me the sleeves. I gotta "test" them out for you...
Seriously though I'd use the GSR crank and go with the Endyn rollerwaves as someone suggested. They're very well designed and you should be able to get away with more compression than you otherwise would. Sounds good to me, let us know how all this comes out.
