problem with brake piston. need help please!
Old Sep 19, 2002 | 11:42 AM
mark72's Avatar
Default problem with brake piston. need help please!
ok, so yesterday my friend and i were installing my coilovers on my integra. when we took of the passenger side front caliper the brake pads fell out and that piston in the brake caliper kinda popped out. Because of that, i cant push it back in to make room for the brake pads so it can fit right on the rotor. I tried c-clamps and a brake compressor. any of you guys know how to solve this problem?
Old Sep 19, 2002 | 11:49 AM
Farnsrocket's Avatar
Default Re: problem with brake piston. need help please! (mark72)
Did the piston come completely out of the rubber seal?
Old Sep 19, 2002 | 11:51 AM
mark72's Avatar
Default Re: problem with brake piston. need help please! (Farnsrocket)
about 1/4 of an inch
Old Sep 19, 2002 | 12:32 PM
mark72's Avatar
help
Old Sep 19, 2002 | 12:49 PM
So the piston did not become separated from the caliper and the dust boot??
The piston may have come out past the seal inside and the seal may have expanded.
[Modified by Farnsrocket, 1:51 PM 9/19/2002]
Old Sep 19, 2002 | 01:03 PM
mark72's Avatar
no, the piston did not become separated. it just popped out about 1/4 inch.but i could kind of see the seal though
Old Sep 19, 2002 | 04:17 PM
79 civic's Avatar
turn it back, it probably turned trying to adjust for the pad thickness which wasnt there and is extended too far. just get a large screw driver or a 1/4" piece of steel adn use it to turn it back
Old Sep 19, 2002 | 06:04 PM
hoya_10fintec's Avatar
Default Re: problem with brake piston. need help please! (79 civic)
this works on rear disc brakes...
Old Sep 20, 2002 | 08:27 PM
3rdGteg's Avatar
Default Re: problem with brake piston. need help please! (hoya_10fintec)
If it's the front, open the bleeder valve a little and then push it in with the clamp....be aware some brake fluid will come out as the piston slides back in so remember to refill it. Now if it's the rear, open the bleeder valve a little and twist the "+" looking groove on the piston back in. Don't forget to tighten the bleeder valve back after the piston goes in.
Old Sep 20, 2002 | 10:13 PM
976's Avatar
976
New User
Default Re: problem with brake piston. need help please! (3rdGteg)
You must have tapped the brake while it was off. Open bleeder and try c-clamp agian, or the brake tool, be patient it takes awhile to figure out what part of the key fits.
Old Sep 21, 2002 | 06:15 PM
79 civic's Avatar
Default Re: problem with brake piston. need help please! (w00t!)
didnt notice if he said front or rear, thats my mistake sry
Old Sep 22, 2002 | 08:56 AM
DR. ON POINT's Avatar
Banned
pop the cap off ur master cylinder.......push the cylinder back in....simple as pie
hondadadcrv
Honda CR-V & Element
Jul 10, 2010 03:05 PM
leviq
Jul 7, 2007 08:28 AM
wickedxbo1
Dec 31, 2001 10:02 AM
