B16 head on GSR bottom end
Old Sep 21, 2002 | 09:57 PM
RacerDre's Avatar
Default B16 head on GSR bottom end
would this be a good idea? pros - cons
Old Sep 21, 2002 | 11:00 PM
miller's Avatar
Default Re: B16 head on GSR bottom end (RacerDre)
the b16 head is proven to flow better, i know that alot of people disagree but it is proven. i have seen many flow charts. the b16 head also will lower your compression a couple of points due to the combustion chamber design compared to the gsr.
Old Sep 22, 2002 | 02:27 AM
InevitableRace's Avatar
yup the b16a head flows better
Old Sep 22, 2002 | 11:57 AM
AzG35's Avatar
Default Re: B16 head on GSR bottom end (allmotrb18c1)
That is the combo I'm running. You should use different pistons to bump the compression, otherwise it will be fairly low, 9.6:1. I am using PR3 pistons (11.1:1 cr) w/ a ported head and GSR cams, I put down 182bhp and 134ft-lbs on the dyno. This combo = poor man's type r.
Old Sep 22, 2002 | 01:04 PM
B19CivicHB's Avatar
Default Re: B16 head on GSR bottom end (AzSi22)
What was your full setup?
Old Sep 22, 2002 | 01:54 PM
AzG35's Avatar
Default Re: B16 head on GSR bottom end (B19CivicHB)
B16A head, mild p&p, GSR intake cam, B16A exhaust (Don't Ask, long story)
ITR valve springs, retainers
B18C1 block, PR3 pistons 11.1:1 CR
ITR IM
JG 64mm TB
AEM CAI
At the time I had a ApexI GT header, now DC JDM
ApexI N1 exhaust
ApexI VAFC
Bunch of other basic stuff, tuned, ran 13.7@99.6mph in a 99 Si (2300lbs w/o driver)
90B16aCRXsi
43
Jul 30, 2008 08:50 PM
L33TsAbabyEater
Sep 11, 2006 06:53 PM
CustomX113
44
Mar 11, 2006 08:41 AM
maziospzza
Dec 2, 2004 12:33 AM
CrazyKoreanCrx
Jan 29, 2003 12:52 PM
