Headwork: re-break in engine, or not needed?
Old Sep 21, 2002 | 05:11 AM
Nacho169's Avatar
Default Headwork: re-break in engine, or not needed?
Depending on which set of my car friends I listen to, i either need to re-break in my engine when the head goes back on (hopefully later today), or i can just slap it on and go ("Only the bottom end needs breaking in). Which one would you recomend?
Old Sep 21, 2002 | 05:19 AM
tk's Avatar
tk
Default Re: Headwork: re-break in engine, or not needed? (Nacho169)
Install your head and drive it like you stole it
If the head job is done right then no breakin needed
Old Sep 21, 2002 | 06:23 AM
Nacho169's Avatar
Default Re: Headwork: re-break in engine, or not needed? (tk)
Thats what i thought. A few of my friends told me i needed to seal the head gasket with a break in, which sounded odd to me. Thanks.
Old Sep 21, 2002 | 06:28 AM
TimoneX's Avatar
New User
The only time I'd say take it easy due to head work is if you changed the cam(s), springs, & retainers. With the head gasket it will either seal or it won't. No need to baby.
Old Sep 21, 2002 | 07:31 AM
earl's Avatar
Default Re: Headwork: re-break in engine, or not needed? (TimoneX)
The ONLY thing that needs breaking in on a new engine are the rings. They need to seat. Every other part is ready to go as is or you are in trouble. Break-ins are a myth put out by the car manufactures (except for rings). The rings on our race motors are usually broken in by the second pass on the dyno.
Old Sep 21, 2002 | 12:57 PM
tk's Avatar
tk
Default Re: Headwork: re-break in engine, or not needed? (earl)
earl 2nd pass? Our engines are sealing will assembling and adjusting J/K
If you use plasma moly rings they seal alot faster than chrome rings
Old Sep 21, 2002 | 03:50 PM
Michael Delaney's Avatar
there's no break in needed. they should have used assembly lube on new cams (if you got new cams as well). you may want to get a new head gasket, timing belt , and head bolts (or ARP head studs) as well though.
bretberger
Honda Civic (2001 - 2005)
Jan 8, 2018 08:23 PM
Ash J. Williams
Jun 20, 2011 10:56 PM
MrMug3n
Jul 24, 2008 09:52 AM
amd41689
Honda Motorcycles
Apr 15, 2008 01:44 PM
ryan_crx
Nov 3, 2007 04:32 PM
