What can i use to plug an o2 bung?
Old Sep 18, 2002 | 03:41 PM
TenaciousC's Avatar
Default What can i use to plug an o2 bung?
I have a cat from a 96 gsr going onto my 95. what can i use to plug the o2 bung on the cat? (besides am o2 sensors you smartasses )
thanks
Old Sep 18, 2002 | 04:31 PM
earl's Avatar
Default Re: What can i use to plug an o2 bung? (TenaciousC)
Most muffler shops stock plugs and I've even found them in large hardware stores
Old Sep 18, 2002 | 05:00 PM
TenaciousC's Avatar
Default Re: What can i use to plug an o2 bung? (earl)
can i just use some kind of big bolt?
Old Sep 18, 2002 | 05:32 PM
BigMoose's Avatar
Its an M18 x 1.5 Thread, one of the old jumbo spark plugs will fit.
Regards,
BigMoose
Old Sep 18, 2002 | 08:37 PM
b18c1civic95's Avatar
Default Re: What can i use to plug an o2 bung? (BigMoose)
A bOlT
Old Sep 18, 2002 | 09:19 PM
tonyxcom's Avatar
Default Re: What can i use to plug an o2 bung? (b18c1civic95)
or how bout an O2 sensor
Old Sep 19, 2002 | 08:45 AM
earl's Avatar
You would want to use a short bolt if you can find one. Hard to find one laying around the house.
Old Sep 19, 2002 | 08:58 AM
newspeedR's Avatar
cheapest and easiest solution... an oil drain plug bolt... most auto parts shop have them and they are the cheapest...
if you look for a bolt for the size, they are going to be more money than the dain plug
Old Sep 19, 2002 | 09:09 AM
ScrapinSi's Avatar
Default Re: What can i use to plug an o2 bung? (newspeedR)
Spark plug... screw it in, tighten it down, and then hit the end of the spark plug with a hammer to break the end off, so that it doesn't take up as much space.
Old Sep 19, 2002 | 09:31 AM
letsride's Avatar
Default Re: What can i use to plug an o2 bung? (ScrapinSi)
The old spark plug trick works good and is cheap!
Old Sep 19, 2002 | 10:00 AM
-Whitey-'s Avatar
Default Re: What can i use to plug an o2 bung? (letsride)
duct tape
Old Sep 19, 2002 | 10:38 AM
JHill's Avatar
Default Re: What can i use to plug an o2 bung? (one_honda)
I machined a round rod with a shoulder on it, and then welded it in place. It is the correct depth to make a smooth surface on the inside.
Old Sep 19, 2002 | 08:01 PM
Batoutahell's Avatar
huh huh uh, he said "bung hole"
Old Sep 19, 2002 | 08:05 PM
CzanSOHC's Avatar
Default Re: What can i use to plug an o2 bung? (Batoutahell)
a short bolt w/ teflon tape on the threads.
Old Sep 20, 2002 | 06:15 AM
David G's Avatar
Default Re: What can i use to plug an o2 bung? (CzanSOHC)
I used an old 02 sensor
Old Sep 20, 2002 | 07:41 AM
LTB420's Avatar
Default Re: What can i use to plug an o2 bung? (H2OCivic95)
I used an oil drain bolt, worked great.
Old Sep 20, 2002 | 01:36 PM
Nameless RB26's Avatar
Default Re: What can i use to plug an o2 bung? (LTB420)
does there even have to be one? What's it going to hurt if it's not there? inform me
Old Sep 20, 2002 | 02:05 PM
Farnsrocket's Avatar
Default Re: What can i use to plug an o2 bung? (Nameless)
an open exhaust......it'll sound like ***
Old Apr 11, 2008 | 03:29 PM
KeyserSoze's Avatar
Default Re: What can i use to plug an o2 bung? (Farnsrocket)
I know this post is quite old, however someone did mention going to NAPA for the plug. Many people at NAPA have no clue what you are going to ask them for so here are the NAPA part numbers (They should both fit). Hopefully this helps the next person looking for a plug.
7041069
7041037 (this is the one i got because they were out of the other one, fit perfect)
Old Apr 12, 2008 | 12:47 AM
civicstar's Avatar
Default Re: What can i use to plug an o2 bung? (KeyserSoze)
i had an oil pan drain bolt on one, forgot what it was from
Old Apr 15, 2008 | 08:03 PM
kicked25th's Avatar
Default Re: What can i use to plug an o2 bung? (civicstar)
(Thanks for bumping this as I may not have found it otherwise. Good info here.)
Go to O'Reillys
I picked up my M18x1.5 Oil Drain Bolt + Washer for 2.29 + tax
Part # 65220
Modified by kicked25th at 8:34 PM 4/22/2008
foxyroxy
Jun 8, 2011 08:31 PM
suckmypistons
Sep 8, 2006 07:57 AM
JinDIESEL
Oct 5, 2004 07:14 AM
CrxSi707
Aug 26, 2003 10:39 PM
TenaciousC
Sep 18, 2002 05:04 PM
