ecu fuse question!
Old Sep 17, 2002 | 04:23 PM
-Whitey-'s Avatar
Default ecu fuse question!
i was told to protect my car from theft all i have to do is remove the 7.5 fuse from the fuse box under the hood!
but i removed it today to test the thory and my car still started and ran fine!
why is this?
is this supposed to happen?
Old Sep 18, 2002 | 06:28 AM
TimoneX's Avatar
New User
Default Re: ecu fuse question! (one_honda)
Who told you that?!? The 7.5 is the back-up fuse. It resets the ECU and stereo. I'd get a high quality alarm rather than pulling any fuses. Keyless entry and auto window cranking are bonuses with a decent alarm.
Old Sep 18, 2002 | 07:21 AM
Mikey3000's Avatar
if you pulled the 15 amp ecu fuse the car wouldn't start. btw i think that would be a good way to keep your car from getting stolen. they would never know why it doesn't start, unless they knew their ****. it would get very annoying to have to keep pulling it every time you parked though.
Old Sep 18, 2002 | 08:25 AM
TimoneX's Avatar
New User
Default Re: ecu fuse question! (Salvatore Leone)
Well you could easily run a swich to it, but it's still ghetto, and doesn't stop anyone from trashing your stuff, like an alarm would. Well at least it'd let you know if someone was.
Old Sep 18, 2002 | 02:08 PM
german_vtec's Avatar
Hi
everytime you pull one of these fuses your ecu will be reset -
this means that your engine won´t run with the optimum parameters after
reset...
Old Sep 18, 2002 | 06:03 PM
BreakStuff's Avatar
New User
Default Re: ecu fuse question! (german_vtec)
Try pulling the fuel pump relay...betcha wont start then... : )
MySelfAffliction
Dec 28, 2009 10:10 PM
BlackGS-R
Audio / Security / Video
Jul 2, 2003 10:32 PM
tmekjian
May 8, 2003 08:17 AM
SIK IN DA HED
Oct 27, 2002 08:42 PM
