Battery or Alternator
Old Oct 22, 2002 | 08:23 PM
Fatty_1775's Avatar
Default Battery or Alternator
I forgot, how can you tell if the battery needs to be replaced or if its the alternator that needs to be replaced? Thanks.
Old Oct 23, 2002 | 02:33 AM
visi0n's Avatar
Default Re: Battery or Alternator (import_racer)
if you can start your car then your battery is fine...if your car slowly starts dieing after being on for a minute or less your alternator is probably dieing...
also when your car is on try disconnecting the negative terminal to your battery. if your car stays on and functions normally then your alternator is fine.
ALLDAY-24
18
May 3, 2011 08:25 AM
Wiretaju
Jun 25, 2010 03:02 PM
obuhmyuh
May 28, 2008 03:27 PM
Scud
Feb 28, 2008 03:35 PM
IHTFP
Jul 30, 2006 07:01 PM
