Headlight Adjustment
Old Oct 22, 2002 | 09:00 AM
Muckman's Avatar
Moderator in Chief
Default Headlight Adjustment
Quick question about adjusting the headlights on a 3rd Gen Integra.
Horizontal Adjustment (on top): adjusting Clockwise/counter clockwise = aiming the headlight right or left?
Vertical Adjustment (on side): Clockwise = up or down?
Doesnt say in the owners manual which direction does what. And Ive tried the trial and error method but it adjusts so slowly I cant tell which direction its moving, if at all, and I dont want to adjust it too much.
Old Oct 22, 2002 | 12:08 PM
Muckman's Avatar
Moderator in Chief
Default Re: Headlight Adjustment (Muckman)
ttt
Old Oct 22, 2002 | 01:19 PM
ion_four's Avatar
On my 93 Civic, the one closest to the radiator is horizontal and furthest outboard is vertical...not sure if that helps. I spent like a goddamned hour adjusting my headlight, then I realized the bulb wasn't clipped in properly heh...might wanna check that
Old Oct 22, 2002 | 01:54 PM
Muckman's Avatar
Moderator in Chief
Default Re: Headlight Adjustment (ion_four)
hah yeah i checked that. I spent about an hour adjusting them like crazy b/c one was really off. I had it pointed against my garage but I wouldnt see the lights move so I would adjust it alot.. then go test it and it would WAY too adjusted heh.. So Id like to just make minor corrections but I forget which way I had to turn the screw driver. And the plastic gear adjuster on the headlight assembly is beginning to strip so Id like to minimize my adjustments.
I figured someone would have a quick answer to this?
Old Jul 19, 2004 | 09:18 PM
ILuvJDMITR's Avatar
i am in the same boat, search ....
ElephantMan13
Oct 29, 2010 12:10 PM
luciffer
Sep 19, 2008 05:23 AM
choppedndropped
Feb 26, 2007 11:19 AM
dLo GSR-stolen-now-WRX
May 3, 2003 12:02 AM
fineglock9
Mar 1, 2002 06:56 AM
