fuel pump?
Old Oct 22, 2002 | 01:43 PM
3rdGteg's Avatar
Default fuel pump?
When would u need an aftermarket fuel pump? Isn't the stock one sufficient enough? (For a N/A application) If not, what are the advantages if any to have lets say a Walbro 190 or something.
Old Oct 22, 2002 | 01:53 PM
NonovUrbizniz's Avatar
Loved
Default Re: fuel pump? (3rdGteg)
you don't need one for na unless it's built
Old Oct 22, 2002 | 02:19 PM
3rdGteg's Avatar
Default Re: fuel pump? (NonovUrbizniz)
really? Anyone else....
Old Oct 22, 2002 | 03:33 PM
Big Phat R's Avatar
The stock fuel pump is sufficient for most N/A applications. If you need more fuel it is wiser to 1) increase injector size and/or 2) increase fuel pressure. Via a programmable ECU you can also change injector pulse.
All of the above would be recommended for a "built" application that requires more fuel than an OEM setup simply due to the fact that you are trying to make more power. (more fuel + more air = more power).
Old Oct 22, 2002 | 05:13 PM
3rdGteg's Avatar
Default Re: fuel pump? (Big Phat R)
so a fpr and my stock ls fuel pump would be sufficient enough for up to 250hp maybe?
integratypeRs
Dec 10, 2008 07:13 PM
lv6l
Jun 5, 2006 09:33 PM
b16hatche
Dec 22, 2005 04:13 PM
