causes of hot cylinders or extremely lean condtions?
Old Oct 22, 2002 | 03:20 PM
dirtySOHC's's Avatar
Default causes of hot cylinders or extremely lean condtions?
as the topics says
Old Oct 22, 2002 | 03:22 PM
Big Phat R's Avatar
Default Re: causes of hot cylinders or extremely lean condtions? (dirtySOHC's)
lack of fuel
Old Oct 22, 2002 | 03:24 PM
Default Re: causes of hot cylinders or extremely lean condtions? (Big Phat R)
wat if you knew that you were getting the right amount of fuel.....?
[Modified by dirtySOHC's, 12:25 AM 10/23/2002]
Old Oct 22, 2002 | 03:30 PM
Big Phat R's Avatar
uhhh - you might be wise to provide a little more information there bud -
Old Oct 22, 2002 | 03:40 PM
i am only trying to find out common causes of hot cylinders. just for means of discussion...........bud.
Old Oct 22, 2002 | 04:06 PM
Big Phat R's Avatar
Answer: not enough fuel
Hot cylinders can be caused by:
1) malfunctioning cooling system
2) malfunctioning oil system
3) too high compression and not enough fuel
4) overbored motor with excessively thin cylinder walls
5) overboosting in F/I
Extremely lean conditions can be caused by:
1) not enough fuel i.e.
i) bad fuel pump
ii) bad injectors
iii) ecu problems
iv) kinked fuel line
2) too high air:fuel ratio i.e. bad ecu, bad 02 sensor, too much boost etc.
Old Oct 22, 2002 | 04:09 PM
see we are getting somewhere. thanks
would a blown headgasket be a cause or piston damage?
where is everyone else on this
Old Oct 22, 2002 | 04:12 PM
Big Phat R's Avatar
A blown headgasket is going to kill your compression - so no
Define "piston damage" better.
Old Oct 22, 2002 | 04:54 PM
maybe that was a bad example.
warped head? cracked? could that create high temps?
[Modified by dirtySOHC's, 1:56 AM 10/23/2002]
Old Oct 22, 2002 | 05:04 PM
Big Phat R's Avatar
no and no
Old Oct 22, 2002 | 05:32 PM
basically wat all my plugs look like
my compression sits at 160 160 165 170 since a blown headgasket would kill my comp then that cant be the cause. and a warped or cracked head is not it then......it would have to be my cooling and fuel system.
[Modified by dirtySOHC's, 2:34 AM 10/23/2002]
Old Oct 22, 2002 | 09:41 PM
bump
Old Oct 22, 2002 | 10:32 PM
CivicEK.PDX's Avatar
****...mine are whiter than that.
Old Oct 22, 2002 | 10:37 PM
B18C-EJ1
Guest
Posts: n/a
BEJEESUS!!!! What the hell plugs are you running? 5's? I've never seen a nose that big......
Anyways, blown headgaskets can be caused by a faulty cooling system, but by the looks of your plug, you've got some fuel/timing issues there.
Old Oct 23, 2002 | 03:12 PM
Default Re: causes of hot cylinders or extremely lean condtions? (B18C-EJ1)
they are 5's....maybe i should switch to 6's. my timing is at 2 degree's retard and i have checked cam timing and everything lines up.
this motor has given me so much bad luck......i need to hurry up and save harder so i can chuck this one out the window.
Old Oct 23, 2002 | 03:52 PM
B18C-EJ1
Guest
Posts: n/a
I would almost go up to 7's (BKR7E), we've had great luck with these on a stock D16Z. Increased our customers gas mileage, and he claims more power (I dunno tho).
bobbyeg6
Mar 23, 2010 04:10 PM
TylerC161
Dec 13, 2006 08:58 AM
DaX
Nov 9, 2004 10:12 AM
Del_Slowest
Apr 7, 2004 09:18 AM
