type R piston w/ b18b head
Old Oct 20, 2002 | 09:48 PM
Dorikamu's Avatar
Default type R piston w/ b18b head
I think it should be ok to use type R piston in stock b18b engine, (well the rod has to be mod to fit)
I just wanna confirm this before I do it... will there be any gain in this setup...
Old Oct 21, 2002 | 05:42 AM
brownshigh's Avatar
Default Re: type R piston w/ b18b head (chusai)
it depends on which ITR pistons your using head gasket etc,yes you will fill a noticeable difference.i have usdm sluggs in my b18 bottem end and other than the rod modd,they work flawlessly
Old Oct 21, 2002 | 01:28 PM
Dorikamu's Avatar
I suppose this raise the compression ratio. will it cause damage to the engine... in other words.. how reliable is this setup...? I am not planning to rev it past 7500rpm
and it should work with stock b18b gasket, or I should change to another kind?
[Modified by chusai, 5:29 PM 10/21/2002]
the.hamburglar
Jan 24, 2006 08:16 PM
Riceintegrars
Jun 22, 2005 12:20 AM
92-LS-Civic
Oct 4, 2004 10:29 AM
bruthaboost
Jul 29, 2001 06:46 AM
