SMS Cat Problems..............
Old Oct 21, 2002 | 06:01 PM
Unsung's Avatar
Default SMS Cat Problems..............
I got the cat from SMS because it came highly recommended. I put it in, worked great for a day... Then a slight rattle started coming from the cat. Now 4 days later, the whole cat sounds like it's going to blow up.
I've heard i you run rich with these cats, the filliment blows out. But the thing is, I wasn't running rich. I was actually running 3% lean across the board.
Anyone else have this problem?
Old Oct 21, 2002 | 06:45 PM
MikeMAN's Avatar
Default Re: SMS Cat Problems.............. (JDM B-Series)
do u think u may have melted the filiment from being too lean? it may all be clogged up now..
not positive but I had a friend that this happened to this past may..
mike
Old Oct 21, 2002 | 09:13 PM
Unsung's Avatar
Default Re: SMS Cat Problems.............. (MikeMAN)
Doubt 3% lean would melt metal. There is no backpressure since it's 2.5" collector back. Anyway, I've heard about lots of problems with these. SMS makes good stuff, I just want things set straight and to get another working cat... and it would be nice to know why these keep crapping out.
Old Oct 22, 2002 | 11:33 AM
Daemione's Avatar
You're not going to break down the catalyst material in 5 days unless you've got some serious problems.
It's most likely just the welds on the heatshield. Probably guaranteed by SMS, as I believe they reweld the ones that go through them to try and prevent that from happening.
But why are you asking us? Call SMS or Carsound.
[Modified by Daemione, 4:30 PM 10/22/2002]
Old Oct 22, 2002 | 11:58 AM
Nikolai's Avatar
Default Re: SMS Cat Problems.............. (Daemione)
Running lean can be a problem if you are having any misfires, since the catalyst will "burn" the mixture in the cat, causing crazy-high temps, which will cook the ceramics. In addition, if this cat does not have a heat shield, then driving through water will cause it to crack and rattle around inside its metal casing.
Nick
Old Oct 22, 2002 | 08:44 PM
Unsung's Avatar
Default Re: SMS Cat Problems.............. (Nikolai)
Thanks for the info guys. SMS took care of it no prob... they are awesome.
Turbocivic94
May 29, 2009 06:46 PM
jflipwa
Apr 22, 2009 06:55 PM
sirminder
Dec 29, 2005 01:04 PM
sporkcrx
Oct 6, 2003 09:15 PM
Maengelito
Apr 10, 2002 06:41 PM
