pulling off head-drain coolant?
Old Oct 22, 2002 | 02:55 PM
3rdGteg's Avatar
Default pulling off head-drain coolant?
I've pulled the head many times before but I always drained all of the coolant out. I was wondering though if I could just drain out the radiator and not the drain plug on the front of the block. I'm just doing a head gasket and nothing with the block so I'm thinking it's not necessary; what do you guys think?
Old Oct 22, 2002 | 02:58 PM
91DA9's Avatar
Default Re: pulling off head-drain coolant? (3rdGteg)
While you have it off you might as well drain it so you can inspect your sleeves and block, as well as ensure you have entirely new coolant.
Old Oct 22, 2002 | 03:12 PM
3rdGteg's Avatar
Default Re: pulling off head-drain coolant? (94IntegraGSR-OVR)
That's a good point and will do that, but it's possible to pull the head without draining the plug on the block right? (Just knowledge for future.)
Old Oct 22, 2002 | 04:17 PM
Tbone's Avatar
When you pull the head your gonna make a mess as well as having some of coolant the spill down into your cylinders, some will even get by your rings and then it will be in your crank case. Be sure you change your oil after.
Old Oct 22, 2002 | 05:10 PM
3rdGteg's Avatar
Default Re: pulling off head-drain coolant? (Tbone)
So I guess it's better to always fully drain the coolant before pulling the head. I was asking because I recently visited a shop who had some cars sitting around w/ the head off but I still see the coolant full all around the water jackets and the head is off--so I figured it would be a cool shortcut or something since the shop always do things professionally . I was just wondering how they do it & if it's an okay idea.
Old Oct 22, 2002 | 10:52 PM
CivicEK.PDX's Avatar
Just drain the radiator...youll be good.
Old Oct 23, 2002 | 02:24 AM
Mista Bone's Avatar
D Tranny Guru
drain rad, then open block drain for 2-3 seconds. That way no coolant will get near cylinders/pistons when you pull the head.
Coolant is cheap. $2.50 for a FULL coolant change, only need a 1/2 gallon of it.
Old Oct 23, 2002 | 04:32 AM
Tbone's Avatar
Default Re: pulling off head-drain coolant? (Mista Bone)
Mista b, your not talking about honda coolant then lol
Old Oct 23, 2002 | 09:00 AM
brcivic411's Avatar
my thoughts exactly... that stuff is like $18
Old Oct 23, 2002 | 09:41 AM
rus's Avatar
rus
Does it really matter if you get or not? Many coolants (such as GM Dexcool - pinkish stuff) claim to be phosphate and silicate free. I normally run Prestone and haven't noticed any problems. Cheap and beats dealing with ******** at the parts counter.
Old Oct 24, 2002 | 03:47 AM
Mista Bone's Avatar
D Tranny Guru
Wanna bet, I used get MY Honda coolant for free from the mechanics. You'd get charged for a full undiluted gallon. But cooling system only needs one gallon of diluted coolant. So every other Civic that got coolant service, mechanic had a full 1 gallon bottle Honda antifreeze.
Now, Honda only sells the diluted kind, but at same price.
RAPE!
Old Oct 24, 2002 | 05:30 AM
jweller's Avatar
I just bought undiluted honda coolant about a month ago from the dealer. so either they are in the process of phasing it out, or where ever you get it from is shafting you
Freemananana
20
Aug 24, 2013 11:46 AM
OH_1fstgsr
14
Jul 21, 2008 06:03 PM
gotboost562
Apr 1, 2007 07:31 AM
shreddinryguy
Aug 1, 2005 07:31 PM
1bar_ek
May 7, 2005 07:57 AM
