Car bogs at random times!!!!
Old Mar 12, 2003 | 06:59 AM
MeanGreenEG9's Avatar
Default Car bogs at random times!!!!
Ok.... this is gonna sound very odd but when the car is fully warmed up and I am just driving normal the rpm needle is jump down when i hit around 1.5k-3.5k... not sure why.. the needle jumps up and down and the car just bogs.. it even does it past the 4k mark sometimes butits not as drastic but you can definitely see the needle jumping up and down very very slightly... i notice this happens a lot more when i'm hitting the throttle when I make some hard turns... I thought it might be the ecu so I unplugged it and plugged it back in.. it isn't doing it anymore but this has happend in the past but stopped in the past as well.... but before it wasn't this bad... i think its getting worse or something
any help?
Old Mar 12, 2003 | 07:25 AM
RCautoworks's Avatar
Default Re: Car bogs at random times!!!! (B16aEJ)
Whens the last time you changed your fuel filter ? I don't see why it would be the ecu. Check all your vacume lines also.
Old Mar 12, 2003 | 09:01 AM
Default Re: Car bogs at random times!!!! (90blackcrx)
As far as I know the fuel filter has never been replaced... you think thats it? if so why only at random times? I have checked all vacum lines.. any ones in particular to look at?
Old Mar 12, 2003 | 09:05 AM
almost forgot... i'm not throwing any CEL's either when this happens
Old Mar 12, 2003 | 09:40 AM
Check your plugs, see what they look like. See if there ngk's. also see if they are gaped right.
Old Mar 12, 2003 | 09:49 AM
RAWB's Avatar
Sounds like symptoms of a bad/faulty igniter, as well. Check the plugs, change the Fuel filter, like the other guys said, too.
Old Mar 12, 2003 | 09:58 AM
Default Re: Car bogs at random times!!!! (RAWB)
the ignitor? my ignition fuse blew out a couple months ago.. but I replaced that and it hasn't blown since... I'm going to replace fuel filter and plugs right now.. update later
Old Mar 12, 2003 | 10:12 AM
RAWB's Avatar
The igniter is different from the ignition, it's in the distributor housing. The bouncing tach and bogging problems are reminiscent of a loose connection to it or a faulty one. Do the Fuel filter and plug thing first, though...
Old Mar 12, 2003 | 10:22 AM
Did the plugs and filter.. no more bouncing tach although it wasn't doing it all day today before i put in the new fuel filter and plugs.. faulty ignitor... why would it only be doing it at certain times if the ignitor is faulty? wouldnt it bounce all the time? and why only on hard turns sometimes?
Old Mar 12, 2003 | 11:21 AM
RAWB's Avatar
This is a common problem on DA's. The ignitor connection gets corrupted by grime and causes a bouncing tach, occasionally. I'm not saying that's your problem, just giving you things to check.
Old Mar 12, 2003 | 03:04 PM
hmm I guess i can look into that.. so what do I do? just buy a new distributer?
Old Mar 12, 2003 | 09:28 PM
zigs's Avatar
Just get a new distributor cap and rotor 35 bucks or something like that is what i payed for mine so it not to bad it was a while ago though could be wrong.
Old Mar 13, 2003 | 07:49 AM
Default Re: Car bogs at random times!!!! (zigs)
Ok I'll try that. Thanks.
Old Mar 14, 2003 | 07:25 AM
cap/rotor/plugs/wires/fuel filter.. still bogs at random times
I am trying to figure out WHY it only does it sometimes and it wont do it other times.. I remember this happend ONCE about three months ago but since then it hasn't happend again till now.. someone said it might be a loose connection with o2 sensor??? I guess I can check that..but I've driven without the secondary o2 sensor before and it never bogged out.. so would it be the primary o2 that goes into the header that needs checking?
Old Mar 14, 2003 | 07:47 AM
madman604's Avatar
try o2 sensor. if its black, you may wanna replace it. it should be light brown.
Old Mar 14, 2003 | 02:20 PM
Default Re: Car bogs at random times!!!! (Turbo E)
I think I figured it out.. i checked the ecu ground wire that is bolted right on top of the thermostat housing....it was loose as ****.. so I tightened it and it hasn't happend but i wontknow for sure until it happens or if it happens. Thanks for your help guys.. If this was all it was then on me!
BlueIntegraBoy
Jun 8, 2011 06:15 PM
95soul
Apr 9, 2010 10:28 PM
NineT1Lude
Feb 3, 2009 07:57 PM
yeah_its_boosted
Jan 10, 2006 03:31 PM
monkeypee
Mar 10, 2003 08:42 AM
