Question about knowing if a ECU is good
Old Mar 13, 2003 | 06:31 PM
Bizarre's Avatar
Default Question about knowing if a ECU is good
I have an ecu that I am going to be putting into my car with the motor swap. The question is; is there a way I can check if the Ecu has any problems with it before actually running it? The reason why I'm asking this is because the guy who I am buying it from says his cousin ran it in his crx and said "it wasn't feeling right". Personally I don't know how you get a "it wasn't feeling right" but that's my opinion. So ya. Anyway to check it? Thanks
Old Mar 13, 2003 | 06:39 PM
eg6ajk's Avatar
Default Re: Question about knowing if a ECU is good (Bizarre)
if its able to rev past 4000rpm, and the PCB/parts aren't burnt then it should be fine.
Old Mar 18, 2003 | 08:33 AM
Bizarre's Avatar
Default Re: Question about knowing if a ECU is good (eg6ajk)
Thanks for that eg6ajk. By the way, you do computer chipping correct? If so can you email me your phone number at mikes_teg87@hotmail.com I would like to speak with you about some stuff. Thanks
xcon0570
Mar 1, 2008 07:54 AM
kixcrx
Nov 17, 2007 01:41 AM
Berlinetta F1
Sep 1, 2007 06:06 AM
Bizarre
Apr 16, 2003 04:59 PM
