Timeframe for subframe tear out
Old Mar 12, 2003 | 05:46 PM
Feuerraeder's Avatar
Default Timeframe for subframe tear out
I just got a skunk 21mm rear sway bar for my EK, and I was wondering just how long I can run it without a reinforcement kit. I don't have the money right now for one (yeah, I know it's like $60, but thats college for ya) but I really wanna put the bar on now. I don't normally drive all too hard and I don't plan on autox'ing before I get the reinforcement kit. I know this sounds dumb, but I'm just making sure there's no immediate (within a month or two) threat of damage to my subframe with my setup.
Old Mar 12, 2003 | 07:43 PM
CRXSi90's Avatar
Default Re: Timeframe for subframe tear out (Feuerraeder)
(I'm no expert).....I would think the less hard you cornered during this time, the longer it would last.
If you don't want to spend the money on the kit, get creative and make your own. (my suggestion would be getting two plates to clamp the sheet metal that it is mounted with the mounting bolt. maybe you could just tie it to the LCA mounting....dunno)
be creative and you can probably figure out something as good/better as what you can buy.
Old Mar 12, 2003 | 07:44 PM
MattG's Avatar
New User
Some people run them without the kits and have no problems. Some people tear everything up. Its hard to say. I'd get a kit though, but if you take it easy you should be OK.
Old Mar 12, 2003 | 07:49 PM
Default Re: Timeframe for subframe tear out (MattG)
I'm definately gonna get the kit sooner or later, but till then I'll be gentle. Thanks guys
Old Mar 12, 2003 | 09:36 PM
elwood's Avatar
Have you seen what comes in these "kits"?
I am going to make my own when I get a rear
sway.....i dont even have the money for that though.
Old Mar 13, 2003 | 06:26 AM
Takeoff's Avatar
I don't know if you have any other suspension mods like stiffer shock/spring but this will help prevent subframe tears. If you have stock suspension or just springs I would definetely watch out. Did your sway bar come w/ the metal plates to reinforce the subframe. If it didn't you should contact skunk2 to have them ship you out some. I bought a skunk2 lower tie bar and it didn't come with the hardware so skunk2 sent it to me.
Old Mar 13, 2003 | 07:57 AM
nijia555's Avatar
Default Re: Timeframe for subframe tear out (Takeoff)
i would just wait to put it on when you get the subframe brackets. The 60 dollars will be well worth it when compared to the price of getting the subframe welded.
Old Mar 13, 2003 | 08:30 AM
I've got H&R sport springs (~2" front, 1.5" rear) and no other mods. The bar came with a metal plate to go behind the subframe and a brakect that bolts through the subframe and into the metal pate behind. it holds the bar out away from the subframe a good two inches, then the D bracket bolts to that. i don't really see how the beaks kit works, it looks like basically same hardware I have now, but beefier, but I don't see how it would protect my subframe any better than what I have no. but it is only $60, and surely worth it.
odogg726
Feb 21, 2007 09:22 PM
confucioussae
Suspension & Brakes
Sep 13, 2006 03:03 PM
confucioussae
Sep 5, 2006 05:04 AM
NathanMorris
Jul 20, 2006 12:14 AM
1clean00EM1
Suspension & Brakes
10
Oct 16, 2005 07:22 PM
