Help! car is not running, possible electrical/ecu problem
Old Mar 13, 2003 | 10:37 AM
Tomek's Avatar
Default Help! car is not running, possible electrical/ecu problem
Well last night I was installing my autometer boost and xmas tree(a/f) gauges. Spliced the a/f gauge into to the ecu using the wire in pin d14(the fatter white wire) like I was told to do and ran my power to the radio fuse and grounded it temporarily to the nearest metal source. Car ran fine, a/f gauge operated like it was supposed to. So I moved onto installing the boost gauge, I disconnected the a/f gauge and ran the boost gauge to the same power and ground for testing purposes. Gauge did not light up like it should(probably a bad bulb but thats besides the point) during this I heard a zap, the radio fuse that I used as my power source blew on me. Put a new fuse in and everything was dandy, radio powered up again and so did the a/f gauge when I retested it. After that I called it a night and would resume tommorow when I'd get a new bulb for my boost gauge. I unhooked everything and started my car, it WOULDNT start. The car would turn over but my afc was not getting any power and neither was the fuel pump. Everything else on the car worked as it should.
Whats wrong?? would me blowing the radio fuse affect anything else? did I fry my ecu? Any help is GREATLY appreciated, this is my daily driver and I need her running asap
cliff notes: installed gauges, blew radio fuse. Replaced fuse and unhooked guages. Tried starting car and would turn over but not start. No power to my afc or fuel pump.
[Modified by AztecEJ, 2:19 PM 3/14/2003]
Old Mar 14, 2003 | 07:52 AM
you69's Avatar
Default Re: Help! car is not running, possible electrical/ecu problem (AztecEJ)
you may have an open circut. hook the all of the grounds (in a perm. place) and try to start.
Old Mar 14, 2003 | 07:54 AM
you69's Avatar
Default Re: Help! car is not running, possible electrical/ecu problem (you69)
also check your fuel pump fuse.
Old Mar 14, 2003 | 11:18 AM
Tomek's Avatar
After tearing everything apart checking all my grounds and connections, and even looking at all my fuel pump wiring a buddy of mine was rechecking the fuses under the dash for the 4323093423th time and noticed that the ASG fuse was missing. Somehow this fuse found its way out and is what caused all my headaches Car is running fine now, thanks for the help
Old Mar 14, 2003 | 01:58 PM
pinoize's Avatar
GOOD JOB 3 LUG!!!!!!
Old May 17, 2010 | 04:13 AM
elbear's Avatar
great.
rustydusty1717
Jun 28, 2008 09:50 AM
7808
Jan 25, 2006 10:54 AM
CrazyModGSR
Jul 16, 2005 03:35 PM
Benjithx
Dec 15, 2004 12:40 PM
Tomek
Mar 13, 2003 11:49 AM
