Golden Eagle Question
Old Mar 14, 2003 | 07:17 AM
1sloaccord's Avatar
Default Golden Eagle Question
I got a question. I am building a motor, the question is I sent my block to golden eagle and they accidentally O-Ringed my block. The head gasket I got is the Cometic High Perfe. Head Gasket and Golden Eagle said that it is not compatible with a block that has been o-ringed. Then I called Cometic and they said I can use the High Perf Head Gasket long as the rings are copper. I am confused and need expert advice from you H-Ter’s. Thanks.
[Modified by 1sloaccord, 6:43 PM 3/14/2003]
Old Mar 14, 2003 | 09:26 AM
torr's Avatar
Default Re: Golden Eagle Question (1sloaccord)
send it back and get it done right
Old Mar 14, 2003 | 09:35 AM
1sloaccord's Avatar
Default Re: Golden Eagle Question (torr)
Can't whats done is done
Old Mar 14, 2003 | 09:55 AM
Spade's Avatar
Call Goldeneagle and ask them what head gasket they suggest.
Then, sell the Cometic.
That's the easiest thing to do.
Old Mar 14, 2003 | 10:07 AM
1sloaccord's Avatar
Default Re: Golden Eagle Question (Spade)
I already spoke w/ GE, and they said the HP gasket from cometic will not work. But when i spk w/ cometic they said that i do not need to order a new gasket. They said that as long as the o-rings are copper that it will work and still seal, and I can use that gasket. My question is, has anyone every tried this or knows of anyone that attempted it. If so did it work.
Old Mar 14, 2003 | 10:08 AM
Spade's Avatar
I wouldn't feel safe risking it. Just my opinion.
Old Mar 14, 2003 | 10:22 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
use ge`s new gasket.
Old Mar 14, 2003 | 12:02 PM
1sloaccord's Avatar
Default Re: Golden Eagle Question (vtecvoodoo)
can't use stock bored 2 over
Old Mar 14, 2003 | 03:39 PM
J2turbo21's Avatar
just use a stock one bored to your cynlinder size.If it helps i ran a oringed block with a cometic 3mm hg with no problems.
Old Mar 14, 2003 | 04:34 PM
HEAD's Avatar
I would just buy the right head gasket so you don't have to wonder if it's gonna work no matter who says so, you can always sell the old one
Old Mar 17, 2003 | 10:46 AM
1sloaccord's Avatar
Default Re: Golden Eagle Question (HEAD)
please post in honda tech, in both categories/
Thanks for everyone's opinions on what to do. But want I really want to know is if anyone has tried that combo out, example:
Golden Eagle's O ringed block w/ copper o-rings together with the cometic High Performance gasket.
Reason why:
Golden Eagle says it will not work.
Cometic Gasket said that it will work.
So if anyone know of or has "heard of" anyone trying this out please let me know. Thanks again everyone.
Old Mar 31, 2003 | 08:30 AM
X-Mazda 3 Racer's Avatar
Well, I always recommend going with a stock gasket. I have used Cometic in the past with fair sucess, but not nearly as much as with a stock gasket. That is all I run on my race and street motors and they hold 40 - 50 psi of boost sometimes for an entire race season!! That's alot of abuse. We have many over-bored stock gaskets in stock and ready to ship. Let us know what bore size you need and we can get one out to you a.s.a.p. Give us a call (909) 592 - 4311. Thanks.
Old Mar 31, 2003 | 08:01 PM
earl's Avatar
Default Re: Golden Eagle Question (GoldenEagleMfg.com)
Listen to what Vince says and not Cometic. You really don't want one o-ring over another. Might be ok but why take a chance? I don't see why they would not trade your HP for a MLS. If they won't, sell it and buy one from GE. They should know what works more than anyone else.
chicklet
May 5, 2017 12:58 AM
AllmotorEH2
Apr 12, 2007 03:45 PM
1sloaccord
Mar 17, 2003 07:02 PM
