radiators support hhelp
Old Mar 11, 2003 | 05:28 PM
project dc2's Avatar
Default radiators support hhelp
hey i got a 95 GSR that i need to replacec the radiator support on, its alreayd been removed i needd to weld on a new one that came with the car, is there anythig i should look out for ? i've done a search and the only thing i see from people is " bring it to a shop" well shiht i can weld soo im gonna weld it on msyelf instead of paying someone to do it. give me some tips (* installing tips not " you shoudl go to a shop tips) thanks guys
Old Mar 11, 2003 | 05:53 PM
CRXGSR's Avatar
Default Re: radiators support hhelp (project dc2)
Did you remove the original rad support? If you did, then you probably drilled out the old spot welds. Well, when putting your new rad support in, drill some holes into it where the old spot welds used to be. So, when you weld the new support on, just fill in the holes.
Also, it's a good idea to get some vice grips to hold the rad support in place while welding.
Also, make sure that your measurements are correct. (ie. make sure that the front end is square, and not crooked).
You should also use "weld-thru primer" to prevent rust when welding.
Old Mar 11, 2003 | 05:55 PM
Default Re: radiators support hhelp (CRXGSR)
i didnt take it off te person im buying it from took it off im guesisn minor front tend collision or it had a JDM conversion cuz i know it got stolen soo gooddd chance it was stolen off the car . aany tips peoplel ?? thanks CRX GSR .. but i dunno picsc would help me a lot ... any tips i shoudl dllook out for etc
Old Mar 12, 2003 | 02:48 PM
bump ...
Old Mar 14, 2003 | 10:41 AM
SDT Project EF's Avatar
how do you put these things on ?? do they go on the rear bumper .. .. i think i need to replace my blinker fluid .. brb
95accord-R
May 14, 2013 08:39 AM
spun95
Welding / Fabrication
13
Oct 11, 2011 09:53 PM
turbotime
Oct 17, 2006 04:37 PM
kraven9
13
Sep 14, 2006 03:41 AM
GSR_96814
Mar 4, 2006 07:56 PM
