HELP! Whats wrong with this#@!
busted out my haynes manual w/ the spark plug chart
looks like its too hot? could be incorrect plug heat range, over advanced ignition timing, lean fuel mixture, intake manifold vacuum leaks, sticking valves and insufficient engine cooling. just a guess.
Well this is an OEM Spark Plug meaning I haven't changed them since I got the car.. So I highly doubt it's the incorrect plug heat range, lean fuel mixture... Well I always use 91octane, and the Prelude runs rich straight from factory according to people..
I got a CAI around December, and the last time I checked my spark plugs it wasn't still there, if I have a vaccum leak on my Intake Manifold how do I check for this
wow, that almost makes me feel better about my old 91 lude. i burnt a little bit more oil than that but i also have 150k. do you beat you car pretty good? those plugs look pretty bad.
a1320honda
Sep 4, 2007 10:04 AM
