compression ?
Old Mar 11, 2003 | 04:36 PM
onefastcx's Avatar
Default compression ?
i have a 2000 civic si block and a b16a head that is milled how much compression will; that be
Old Mar 11, 2003 | 04:55 PM
BabyDaddy's Avatar
Default Re: compression ? (onefastcx)
No way to tell by what information you have given. How much was milled off? Best way to tell is CC the combustion chamber and bottom-end with the piston at TDC. Add the volume of the headgasket... Take that total volume, divde it into that volume + your volume from the stroke of the crank and walla... There's your compression ratio.
Old Mar 11, 2003 | 06:36 PM
onefastcx's Avatar
Default Re: compression ? (BabyDaddy)
im sorry the head is MILLED 40K
THANKS
Old Mar 11, 2003 | 06:45 PM
qtiger's Avatar
40 thousandths?
My rough guess is 10.3:1 or 10.4:1.
Old Mar 11, 2003 | 07:29 PM
onefastcx's Avatar
Default Re: compression ? (qtiger)
um there is no way if it is milled 40 k that it will only be 10.4 man it will be like 11.3 11.4 i know that i just want an exact number
Old Mar 11, 2003 | 07:35 PM
TREVER's Avatar
11.3846759637649 I have cc x ray vision
Old Mar 12, 2003 | 11:18 AM
onefastcx's Avatar
Default Re: compression ? (TREVER)
allright !!!!! thanks TREVER how did you find that out what mathamatical equasion?
Old Mar 12, 2003 | 11:29 AM
texan's Avatar
There isn't one. Mathematically the largest chamber volume possibly taken away from a 1mm head mill will be 6.5cc, so potentially the compression is as high as ~11.8:1. However 1mm of head mill doesn't equate to that much chamber volume loss, but the only way to know for sure is to cc the head and then do the calculations. If you figured a 5cc loss in volume you'd have 11.4:1.
Adam_b16a
Nov 30, 2009 08:29 AM
teamXteg
Apr 12, 2006 08:35 PM
0bd1_Kanobe
Mar 19, 2004 01:30 PM
Bnjmn
Jun 26, 2003 01:08 PM
4doorH22
Sep 7, 2001 08:29 AM
